0 Members and 353 Guests are viewing this topic.
ronotte
Hi all,
Tesla suggested circuit with center tap primary is nothing special: simply a balanced input connection. I've built many TMTs with different input configurations and I assure you that you can go both balanced or unbalanced without any difference...providing you drive the primary & secondary with correct matched impedance.
The kacher case is equivalent as the primary is connected hot side to transistor collector and the cold side battery (hence low path to GND), secondary is connected to transistor base that is at almost 0V (actually 0.6). Of course transistor emitter is connected to battery minus and in turn to a ground connection. If you take the load from one wire trough the slotted Cu tube than the other wire must be also connected to GND.
As far as now I've tried the focusing method suggested by jbignes5 but I've not found any good results. It is true that working at 1.2  - 1.5MHz it is impossible to wind a folded coil as the coil itself at 1/4 wave is really too, too long (it should be phisically a bobbin). Practically I tried with 80 + 80 turns. Test is in progress.
Same results with bifilar unconnected shield wounded over the bifilar load coil.
Roberto
sparks
A Tesla transformer accumulates standing waves in the secondary. Envision a piece of coax aka wave guide inputting rf with a standing wave ratio of infinity. Not one wave gets out of that piece of coax. The energy supplied to the primary is stored inside the coax. We know that coax is a wave guide. In order to transmit em waves to the radiative element it is tuned to the antennae so that a quarter wavelength or a wavelength of a harmonic of the fundamental frequency employed "stands" on the antennae not in the coax. The current flowing in the antennae mast between nodes and antinodes then propogate perpendicular to the antennae mast in an everexpanding torroidal field of diminishing electromagnetic disruption of space it propogate through.
Anyone who has ever popped finals in a linear knows to avoid sws in the transmission line.
Tesla figured this all out over a hundred years ago. He systematically created a huge piece of coax. Now how does Tesla introduce his power from the scource to the coax?
Study his notes. Study the construction of his primary. Study Crookes' tubes. Study coronal discharge losses on transmission lines when one line is deformed compared to the other. Study the true nature of charge and why the magnetic field about a single charge is in alignment with the electric field about that charge and not when the charge moves. Study what Tesla was going to do with his hemispherical terminal on top of the MT. Study why Tesla combined geometry and algebra in determining capacitance and inductance. Study electron cascade events and see where the energy is coming from to manifest these events. Study how coronal losses can be converted to coronal gain.  Then build a real Tesla transformer.   Power her up.  Turn off the lights.  Tell me what you see on the load cap.  You don't see anything interesting and have to resort to putting pointy pieces of metal near the terminal you haven't got it yet.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
jbignes5
 After rereading most of the tesla documents on Tesla Universe I came across something of interest that most people do not know.
Variable capacitance.
[size=78%]http://www.teslauniverse.com/nikola-tesla-article-teslas-new-discovery?start=70[/size]
sparks
Quote from: jbignes5 on June 18, 2012, 02:29:53 PM
Nice. 8)   Checkout the work of William Townsend Brown.
Think Legacy
Spread the Love
forest
and that variation is probable cause for some grid failures
