energia9
http://en.wikipedia.org/wiki/Multipactor_effect
http://home.earthlink.net/~jimlux/hv/multipact.htm  :)
http://tech.groups.yahoo.com/group/free_energy/message/5971
http://journal.borderlands.com/1988/the-farnsworth-multipactor-tube/
http://www.energeticforum.com/renewable-energy/9927-farnsworth-project.html
read all of them you might thank me
just what i have been saying in my pdf
I know this is the way..
And Multipaction effect can be the reason why kapanadze works,
because multipaction effect might work between two HV HF Tesla coils too! :)
[Editor's Note: P.T. Farnsworth III told Eric Dollard that the multipactor tube and the Tesla coil were a marriage made in heaven! TB]   source journal.bordelands.com
in tesla coils  sender is the emmitter     the receiver is the collector.
also if tesla discovered multipaction effect first,  it was said that tesla used only vacuum tubes to generate power for his car.
This would be the alternative to the tesla coils which are big and heavy.
I think as Tesla discovered effect he developed it further to be a smaller device.
it is also interresting to note that Aluminium is a very interresting metal, Tesla was mentioning the same.!
jbignes5
Yes there is plenty to read on Tesla and should avail oneself to reading everything he said in print. It's funny to note that Tesla thinks the electron was mistaken for hydrogen molecule. He also believe that matter in itself was nuetral and only reacted to the field around it. Radioactive matter seemed to reflect this field and looked like it radiated energy from nothing. Obviously he has a point there. Most other matter contains energy because of the field. Like we are finding out from Itsu's experiment that I asked him to do. This field changes the conductive properties of anything within the field and enhances the capacitance element of all matter. I'm thinking the matter swells slightly from the increase of the electric field in the matter.
I agree with a lot of you guys but we should go back and re-educate ourselves to the real ways so we can do this right. Traditional approaches are not cutting it and now we should look to the man who was right on almost everything he predicted and did experimentally. He wasn't just a book worm he had a fundamental understanding of the reality that surrounds us. This is the main reason he was called a wizard. Although he didn't perform magic he knew the real way things operated in the universe.
itsu
@ Jbignes5,
Quote@ itsu I wonder what would happen if you wrapped that coil around a resistor... Would the resistor get energized as well? And finally around a solenoid coil and read the output from the coil. Tesla said to terminate the load with a mass of metal. Thats why you got no results from the other tests.
I did some further experiments like using a resistor (220 Ohm/50W) wrapped with a coil (so an inductively coupled resistor), which managed to put a glow in a paralleled 230V/25W bulb.
Nothing spectacular but it let me work/learn with the physics involved
A (virtual) ground on the open coil end has an ill effect on the performance (slower cap load rate).
A word of warning about the Power supply:
I use 2 12V batteries in series creating 25V, but i have burned up 3 times now a 0.1uF ceramic cap placed over the plus/minus to decouple the RF.
I think these caps are rated 50V, but they go up in flames, so be aware when using a Power Supply.
You can see one blowing up in the 2e part of the video: http://www.youtube.com/watch?v=hq2ayjeFTvs&feature=youtu.be
Regards Itsu
T-1000
Quote from: itsu on June 19, 2012, 08:06:56 AM
@ Jbignes5,
You can see one blowing up in the 2e part of the video:  http://Http://youtu.be/hq2ayjeFTvs
Regards Itsu
The capacitors on battery react in same way as capacitors near Tesla coil. So high voltage spikes there too I guess.
Also when you use ferrite please be careful, it is quite easy to cause NMR in it with katcher and field surrounding coils on 90 degrees when you put ferrite in coil on horizontal position inside of grounding choke near vertical Tesla coil.
If you would like to make intentional cause, wind selenoid transformer on ferrite and put HV capacitor with spark gap then connect wire inside of ferrite core over length of selenoid. Then see how transformer consumed current drops when spark gap fires... ;)
Cheers!
jbignes5
@ Jbignes5,
Regards Itsu
Your link fixed
Ok you have a really nice lab.
With that being said these are some great results.
Ok some things that are apparent with this system. So inductive coupling is the way to go. I know you want to see something happen but stay away from ferrite or iron cores.
The cap across the battery needs to be rated the highest full voltage of the system. I agree with T-1000 when he says the cap is exposed to the katcher field and hence will generate the voltage across it, negating the effect of the cap for isolation. What is the reason for the caps there? Just remember the field is pretty big on the katcher and your batteries are in that field. This should energize the batteries like Bedini did and cause a recharging effect that can last for hours or days even after being exposed.
ok just wanted to see what the outcome would be for the resistor to see if it could be energized.
I am quite surprised that you can induce the charge even on a metal cap. Hmmm very interesting. I would say though the other cap is gonna be the winner! So I can't wait for your arresters to come in the mail!
One other mention of your setup. You might want to try a one turn coil on the primary. Tesla said it was the best way to see this effect or try a simple bifilar coil if you want to try multiple turns. You want the primary free of resistance even inductive resistance. This should increase your output to the max and you should be able to lower the input to safer levels.
While we are waiting for the the parts to come in could you try a metal bar in the coil like copper or aluminum. If that shows effects then my capacitor made with two pieces of copper or aluminum made as a crude capacitor just might work. We know there is aluminum in the caps right?
I will be starting to build this thing so I need to know your exact setup if you could jot it down for me. There is soo much I want to test with this heh and you have been very instrumental in my current research. Thank you for being so kind and generous with your time and help.
One other thing I wanted to ask you Itsu, How are you feeling in the field? Is there any effects that you can feel like ringing of the ears or prickly feeling on your hands and arms? Any feelings of well being or being calm in the field?
After watching the video again I see you have not used the block of copper or aluminum like I asked previously on the other end of the coil around the cap. This should give a balance to the system that is missing atm and you should have different weights of metal to see the different effects of the different sized blocks. You are correct about the bleeder resistor and it is loosing to much power that way. Since you have a spark gap you don't need the resistor across the cap. Unfortunately that isn't an option with that cap.
*edit* Sorry I didn't see your post about the added metal to the other side of the coil. Disregard the comment then... How big was the metal used Itsu? Was it the same size and weight of the copper inner tube? Tesla said the bigger the better.
