0 Members and 137 Guests are viewing this topic.
energia9
today i just did a quick play and i didnt know that we can draw sparks from a plastic tube some 1 cm away from the inner coil.   the spark that i can draw from the plastic tube can strecth out 2mm , plastic tube is 3mm thick
the purple wire is just a wire hanging in my hands
pretty interresting..
can there be relation why kapanadze did not use enameled wire but pvc plastic coated.. hmm
stivep
Quote from: energia9 on June 20, 2012, 02:31:37 PM
@Stivep
I like your theorizing. it may help anyone and get inspired, but at the same time many will not understand and just dismiss, Because they need allready tried out practical proof.
Man i would love to see experiments performed by you,  because you are a great experimenter.
a wonderfull mind.
if you would take videos of your experiments it would be so great.
i think we would be much closer to Teslas secret
Thanks for all your sharings.
Peace
@T1000  HAPPPY BIIIIRTHDAY! LIVE +100 YEARS :)
Soon my friend soon I think.
I got some breakdown 5 days ago.
or should I  call it brake-up
That was positive event ....... the importance of LW rise to top of my priorities.
I spoke with TK many times  for the last 7 days..
Although he is reluctant to cooperate
I got some hints.
I urge you to concentrate on longitudinal waves
Analyze carefully Eric Dollard work.
Recently I was in contact with many Big Names.
Eric is the only person on planet earth who knows how to deal with LW.
Some of statements you will go across ,very controversial:
LW goes  across the earth without the losses
LW does not have wavelength ( well.. it does but somehow differentiated explanation of it)
LW can have  different speeds
LW can go faster than light.
LW does not use electricity till is associated with load.
LW  the energy send = energy returned  if there is no load.
Yes it is enough for traditional scientist to put  that all into denial.
Anyhow this is my input to this forum
I hope I will stimulate all of you  in  any possible way including my experiments
Happy long life  Arunas
Wesley
Zeitmaschine
Quote from: stivep on June 20, 2012, 05:38:21 PM
I got some hints.
Yes, I could use a little hint: Why are there two patents from Tariel Kapanadze on record?
First one is:
INDEPENDENT ENERGY DEVICE
Inventors: KAPANADZE, Tariel (Tzkaltubo Sokak, No:9, Tbilisi, GE)
Application Number: TR2007/000050
Publication Date: August 28, 2008
Filing Date: June 08, 2007
http://www.sumobrain.com/patents/WO2008103129.html
Second one is:
ENERGY TRANSFORMER
Application Number: TR2007/000062
Filing Date: July 03, 2007
http://www.sumobrain.com/patents/WO2008103130.html
What is the significance of this?
jbignes5
 I'm not sure about those patents. I call into question the validity of the documents. If you read the first document it clearly spells description right but on the second patent in the pdf it says clearly desacription. Now I don't know about you but it looks like they are forgeries to confuse us.
I'm sorry but it is clear that Mr. Kapanadze was using two separate grounds per the 2004 video, the water pipes and the buried radiator. And what is in the second patent is not what he shows in the video! Clearly there are 3 coils and not two.
stivep
Quote from: Zeitmaschine on June 20, 2012, 07:20:39 PM
First one is:
Second one is:
ENERGY TRANSFORMER
Look at  date  of filing:
This one is June 08, 2007
Quote10- An independent energy device of Claim 1 wherein characterized to include the second bobbin (10) to generate electric energy combining the electro magnetic field received from the first bobbin (6) and the independent energy received from the air, after the frequency stabilizer (adjuster) (9) orders the electro magnetic field between the bobbins
This one describes  device receiving energy  from  surrounding field or to be more  specific from unknown  or  undescribed. source of energy
Longitudinal Wave of Tesla :)
If this happened to be true than it is much more than  previously  expected from  TK device even if for some of you it looks opposite . :)
JOHN HUTCHISON  EXPERIMENTS  OTHER THAN TRANSMUTATION ARE INCLUDED HERE. :)
I'm just afraid to lose credibility by  going to specifics.As it sounds  nonscientific.
You should listen to T-1000 explanation of Hutchison experiment.
This one is July 03, 2007
QuoteThe economical energy transformer improved with this invention has to receive energy from a power supply constantly. This mentioned energy can be easily generated from a small accumulator or chargeable battery or an inverter or a network or any similar power supply. The economical energy transformer improved with this invention increasingly emits the energy that is received constantly.
What is happening here is that Turk is the guy who is assigned to the patent with 50% of profit from future manufacturing.
and device is in the group of perpetual motion machines.
No chance for patent
The second one  says  that power comes from battery.,
TK showed me flashed in front of my eyes Turkish one that  he says does not require drawings.
He said that this is a patent.
In reality there  is no patents of TK that I know of . All are just patent applications.
It  for me looks like after filing first one  there was attempt to file something that is patent able at least somehow in any possible way.
but:
This was to much.
they  try to snick in  this wording OU. so even if they say it is different device it would be actually the same.
That is why there was no patent.
Eventually TMZ sized its operation, and TK went home.
Push of TK  for  hydroelectric device was nothing more like  electric device that had additional module just to be able to hide details of electric device in  big  body , as public  becomes more educated.
Eventually trying to patent this approach  taking to consideration past mistakes.
Wesley
PS:
Although I  officially stay that I'm friend of TK you need to understand something.
I DO NOT GIVE DAMN ABOUT ANYONE OF YOU INCLUDING TK IF AND ONLY IF FOR SOME REASON IT APPEARS THAT  THIS  SOMEONE IS PIECE  OF S...T
I'M NOT FOR SALE AND I WILL NOT LICK ANYBODY SHOES.
