baroutologos
So Grizly you think I have not thought that? :)
The possibility that Tesla coils create more power but in HV HF so as to not be so easy to capture?
Look my setup few weeks ago:
Running Tesla coil, arc-gap set on a distance. This goes to a 100nsec, 10Kv, 1amp fast diode bridge and then to ground. The bridge is connected to a 0.125nf 10Kv capacitor that is allowed to spark via at 3-5 Kv spark gap.
Findings:
Firing rate was measured and results are consistenly under unity. Actually some 20-30% efficiency that method. I have used also the 20Kv, 100nsec, 0.1amp diode bridge with same results.
Of course you can argue that the 10kv or even 20Kv is too little for the running TC. But since the dridge is not connected to any inductunce (capacitor actually) and since capacitor is discharged to 50% of FWBR rating, then no problem arises i guess. Bridge is un-damaged anyway, plus for cooling pursposes is put into oil. (no heating anyway)
Also i have used my Kacher in the very same setup. Less efficiency was seen. The most efficiency anyway i can get from this is the top of the TC to discharge in the electrode that is connected to another coil and then to FWBR.
I have seen that if the other coil is of the same specs as the resonantor, then instead of diectly sparking, you can have the wire on the proximity of the coil as an antenna and yet a 20% of power be collected that way.
I do not know if i had some 10 similar coils around the main resonator what the results would be. But initial findings indicate that no magic in this trend. (plus i have not the determination to make 10 coils around)
What i say is not hearsay. Actually i have conducted much experimenting in LC circuits. I do not expect to get COP 30.000 as Don Smith or Kapanadze claims with first shot. BUT, to be consistently under unity suggests that either those fellows have other technology than mine or they claim just bull...
baroutologos
@Xeno,
Actually what you say is true. But bear in mind Larmor frequency is magnetic flux intensity depended.
So by applying some heavy pulses in a primary circuit - thus creating intense B field, and by having another coil resonating at another frequency (Larmor frequency) maybe you can achieve magnetic resonance at 1Mhz or less range. If there is any energy there, you could use a third coil for collecting output pulses.
Actually this concept has been reported by Patrick Kelly.
Go read Chapter 3, device "Micheal Mayer and YvesMace isotopic generator" and compare it to a Kapandze device of 3 coils and the suggested output.
http://free-energy-info.co.uk/Chapter3.pdf
grizli
Quote from: baroutologos on April 01, 2010, 10:21:30 AM
Findings:
I actually dont mean "you are wrong" better to say I so not agree with your opinions :D
VERY nice setup
BUT I think you need THICK wire not classic TC .. that barrel could be good
I just want to make that experiment under very careful conditions measurement to be sure :D
ALL energy in LC is reactive: all energy is equal to full capacity charge.... SO if we discharge capacitor when charged in LC resonance we use full reative(VAR) of capacitor hmm
mabe.. maybe.. like smith says
I wonder what else we could do
baroutologos
Actually Grizly,
i have tested that yesterday with my Magnifier coil, as well as today perfomed some experiments with bulbs connected in series with resonator's ground as well as with a 3 turns isolated coil (magnetically coupled) at the base of the magnifier. (no FWBR in that)
Persistency in under-OU remains. By the way, the magnifier is made by 18awg (extra coil) 1,5mm 1mH base drum coil. The primary is quite thicker (8 awg multistranded) Power supply 30-40 watts max.
I have scheduled another series of experiments though, but i can tell you with being moderately sure that no OU here, only some beautiful results.
See my magnifier's setup and todays experiments.
grizli
Seems like free  energy is like discovering wheel something completely new not related to what we have learned related to EE ::)
