0 Members and 161 Guests are viewing this topic.
jbignes5
Quote from: verpies on June 23, 2012, 07:50:21 PM
Including the energy that was expended to produce the solar panel?
P.S.  @ all
This is a technical thread and not a place for psychoanalysis, sociology and bureaucracy (patents).  I have a lot to say about those matters too, but I keep it down to private messages, as not to distract the engineers and scientists here from technical details.
A technical thread? Please explain?
Engineers & scientist? Most that are here are not of those two divisions. And since when have scientists or engineers not been concerned with All of the above mentioned points? It weighs heavy on all of the engineers and scientists. It is the exact reason they do not go forward and research into these fields.
Example:
http://www.rexresearch.com/correa/correa.htm#5449989
We as scientists or engineers must approach this subject based on all of the mentioned stoppages of our research because most are afraid of loosing any credibility based on those subjects. It needs to be addressed in all of these threads. We must change our system of don't go in that area because you will destroy your credibility. It is a must to discuss this all the way through our discoveries.
If you read the above link you will see in figure 17 of the first section that Tesla did find a way to contain the discharge of the gap in an enclosed gas filled container and get the required power to run devices like the Tesla Roadster project. Unfortunately Tesla never got to patent this idea or it was blotted out to keep us addicted to his first system. One that by the way chains us to someone else supplying the power for which we would pay anything to keep.
Read all the context of this new system from the link above and then try it for yourself. This is what I am gonna do. If you don't then how could anyone call themselves an engineer or scientist. We rely to heavily on videos as proof and to tell you the truth they are highly subject to deception, both in the working principle and the ability to fool people. As a scientist I rely on doing experiments to prove the facts to myself and no one else. A video after all can and will be deceptive. But an experiment that is done by you can not be so.
As for the TK system. The only way to use that system atm is to lock it to the earth and not use it as a portable power system. This new system opens that up to unlock energy from the environment without tying it to earth. Maybe I should look for a thread based on the new system. If there isn't one already I should make a new thread and concentrate my investigations to that new approach.
TK isn't sharing his discoveries so whats the point anymore?
If you would like to keep on with this avenue then look here for some very interesting experiments that I have confirmed by experiment. It's in German I think??...
http://www.hcrs.at/KAPTRAFO.HTM
itsu
@ all,
I Did some further testing with my capcoil.
# measured the temperature rise of the copper/alum. pipes.
   conclusion; its not the interaction between the metals.
# paralleled 2 capcoils (also put in series).
   conclusion; power is not coming from the grounds but from the kacher RF which is limited.
# tested a capcoil as closed loop (30uF cap, 360V SparkGap, 25W/220V bulb, 100 turn coil (awg 26) around the cap) exited by another coil (30 turns) around the capcoil.
  conclusion; after firing of the SG, some RF (fed by the Kacher) stays circulating inside this loop causing the SG to glow conduct/short?)
Video:  http://www.youtube.com/watch?v=shugSQP9nqM&feature=youtu.be
Regards Itsu
Qwert
Quote from: forest on June 23, 2012, 06:23:00 PM
Otto's theory may help if you know it.... He mentioned he had it that time.
He mentioned he had what? A theory? To my knowledge he had several theories; two months ago I completed reading all his posts in English language (he had also some in German). In this document he describes particular experiments and thus creates another theory; this experiment is not mentioned anywhere in his posts. This russian site (http://realstrannik.ru/forum/29-tpu/267-tpu.html?limit=18&start=3276) presents Otto's earlier findings, and not this one (I did not find mentioning this document or these findings after reading about 100 pages).
In fact, I guess it's pretty easy to set this kind of experiment. Problem is, I do not have necessary equipment (at least a pulse generator) and rather don't consider buying one since it's rather expensive and I'm not professional in this field to use it for other projects. So, my intention here is to inspire somebody to help me (I can build the contraption).
jbignes5
Quote from: itsu on June 24, 2012, 01:17:10 PM
@ all,
Regards Itsu
Nice going Itsu.
Ok what you have there is a charging cap but because you are using the AV plug it causes a buildup of positive energy an when it fires the gap it shorts and holds the connection open. Thats seems to me to be very interesting.
Is it possible to move the one end of the bulb to the ground? The spark arrestor is only to protect your cap from over charging. You want to tap that charge from one side of the cap to the ground to use the load. you have it in between the internal coil and cap right?
Another experiment is to not use the av plug at all. Will the cap charge that way with the arrestor across the cap? Then hook your load across the gap with no ground at all... the AV plug is acting like a virtual ground that allows circulation inside of the cap and I bet it is polarizing the cap as well. This might be useful but I don't think that is gonna work for this application.
Just some ideas to try in your experiments.
You might not want to use the katcher with the spark terminating into the copper pipe on the top. Try to use it only the way it worked the first time.
If you use the AV plug just realize that it converts the signal to all one polarity or flow direction in the cap. If you do that you must use a dc load. Without the AV plug it should be used much like ac. The AV plug half rectifies the signal and changes the output to all one potential. The output of the katcher is most likely pulsed dc which is high voltage. This is an energizing voltage field. Anything within the field is energized like you originally discovered with the unconnected cap coil. You need to approach this from that point of view. If this is a singular polarity field then you need to design the load off of that fact.
Farmhand
Quote from: jbignes5 on June 23, 2012, 02:33:18 PM
Huh? What has happened to you Farmhand? First you are poisoning the energetic forum and now you come here trying to disuade people from figuring this out. Why bother? If you think this has no merit then move on you troll.. I used to think you were a pretty open minded individual. Now I know better.
You don't like it then don't bother coming here.
What about the links I just posted that state they are using atmospheric energy to run the earth probing energies to find resources. A purely passive circuit.
Lets think about this for a second here.
Tesla made a working active way to transmit power over hundreds of miles with no connection other then the ground. Now build a hydro power station and hook that to it. IS THAT NOT FREE ENERGY? Other then the investment to the stuff needed for both stations and receivers the energy from a water fall is FREE! The transmission looses 5 percent at most..
As to these other guys, we are investigating and trying to learn better ways to get what we need. If you can not help then go away please.
AS to your P.S. Have you built anything and actually experimented with the setup or is it you want to be handed the instructions with no clear understanding of what you are doing? Experimentation is a game of trial and error unless you have the ability to do this like Tesla did. For which I highly doubt you have an IQ that equals his or a mouse for that matter. Seeing that you have debased yourself into a simple troll making claims as bad as some of the ones you point out.
P.S. Like I said before if you don't like it then there is the door.. We have learning and experimenting to do..
As far as I am concerned it is you who does no experiments, you just waffle on.
You called me a troll and I am not so from now on after this post I will consider you a paid shill and ignore you.
I've built plenty of things and of my own design and they work as well, but my objective is not to gain energy from nothing.
You say I poisoned energetic forum. Haha poisoned it with what ? The truth !
You don't get to tell me where I go and what I do so check your ego sonny.
I encourage people to work it out. What I see is people just believing something is possible and try a million things
while encouraging others to think like them. I've exposed and explained a few things as fakes and how they are faked or could be
most don't like to accept the truth and so call me a troll. Their bad.
No one does themselves any favors by being gullible. The more I learn the more I can see how much BS is going on and who is doing it.
Where are your experiments ? Show us some.
Why is it not possible that Tariel is transmitting his own  energy from his own transmitter, and what we see is the receiver and the receiver only.
For any demonstration to be valid it must be done with a third party skilled to tell if there is
an undisclosed input or the experiment should be conducted at a neutral location. But Tariel doesn't want to share his device details does he.
I think it is important for people to say if they think something is a fake and how that could be so. That way there are less people taken into scams.
There are many scams and fakes are there not ?
I have a busted back and suffer agony every day but at the moment I am working on a picaxe controlled solar charge controller
that can make better use of low light and rain conditions to rejuvinate the battery during rain and low light, it uses a boost function
it kicks a regular charge controllers ASS in low light. I designed it myself built it myself and learned the code so I could write my own
programs. And I did and it works.  I am learning and building stuff that is useful.
You go away.
