0 Members and 49 Guests are viewing this topic.
a.king21
Quote from: Farmhand on June 24, 2012, 04:58:12 PM
To all the guys with some electronic  experience or knowledge/training.
How about some of you choose an inexperienced experimenter and mentor that experimenter.
Help the person with technical assistance on a one to one basis, encourage them to think and learn.
Teach !
I see a lot of folks struggling, myself included to build the circuits we need to experiment.
There are two main aspects here, the principals and the methods to execute them.
We can all come up with theories of principals, that's the easy part. Building the hardware
to test things with and experiment without constant frustration is difficult.
What's needed in my opinion on these forums is not more opinions and untested theories.
What I think is needed is more experiments and testing stuff out, cooperation and helping.
Everyone wants to jump straight in the deep end without learning how to swim, then call out for help.
Why not learn how to swim first, then jump in.
We need to work together, and be able to recognize what is worthwhile investigating.
That requires real world experience, knowledge and experiment/testing.
Cheers
I agree with Farmhand. There is only one possibility that Kapanadze is an investment scammer and that is through the wireless or single wire transmission of electricity. It only takes milliamps at 50 kHz and 30, 000 volts to scale down to kilowatts. The single wire way is through his ground wire using Tesla's single wire technology. The "wireless" way also uses a ground earth wire. Also you would feel nothing even if you touched the ground wire. I have done some ground wire experiments so I know.
However on the positive side we have all missed that his patent tells us how to build his device.  I would focus on the patent.
Kapanadze uses the regenerative principle for his device - if genuine.
If genuine - the earth is probably used to keep the device  in phase. This has been verified by experiment by me also.
In a device of this nature parasitic capacitance builds up. Momentary grounding removes this parasitic capacitance.
Read and re-read his patents  - it's the biggest clue we have.
jbignes5
 Ok  I'm done with it....
Lets move on.
Did anyone check out this link of a system that has been tested and needs to be verified. Also this team has patents..
http://www.rexresearch.com/correa/correa.htm#5449989
They are reporting some 300-500% gain but I will let you explore that yourselves. Check it out it looks promising.
It also deals with plasma arcs and polarization of the spark gap like Tesla reported.
Also I am gonna be starting a replication of kapanadze system from 2004. The exact replication. I think his system just utilizes ground loops which have been a bane to most electrical systems. I know I had tons of troubles eliminating them from house wiring and devices that do not isolate the ground from the working unit. Computers are very susceptible to these loops. In fact one loop was soo bad the electric companies ground connection was cherry red. By the way the ground wire was 3 inches thick and glowing red but not one effect could be seen but for the interference to the computers. Once the ground loop was figured out all the computer systems worked flawlessly.
Ground loops can be very powerful with very heavy current flows. Of course with those flows a huge magnetic component was associated with it. This tended to pick up and amplify any signal and inject it into the AC system. You would think the power company would have known about it but they even were scratching their heads. They tried everything and it only took me about 2 hours to figure that out and fix it. They had to buy a new air conditioner but it was worth it in the long run. Something was wring in it and even when they took it to be examined by a qualified repair man he gave it a clean bill of heath. Yet when put back into the system in the exact spot as before it happened again.
Think about the amount of current flowing in that loop to turn a 3 inch ground cable cherry red. I didn't have anything to measure the current but the power company said that it was impossible to do what it was doing, yet it was happening.
Now thinking about the ground loop and the current it was carrying if you put a coil around that what kind of current do you think you would induce off of that? Maybe thats all Kapanadze is doing? Creating a ground loop by exciting the separate ground connections through the coils then sucking off that loop. This is what I'll be testing because it is better then energy from no where.
In fact I'll do one better. I won't be coming back. You guys and most of humanity can't handle this information. So I will leave you to your silly fantasy world. With made up mathematics and limited vision. I will complete my studies on my own and let you guys blow yourselves to hell. Because that is all you deserve.
It is no wonder Tesla and others gave up and now I have too. It's what you deserve.
One last parting gift for Itsu...
sparks
Quote from: sparks on June 23, 2012, 10:59:50 AM
  I believe the below link will clear up alot of the mystique surrounding this device.
http://www.rexresearch.com/chernetskii/chernetskii.htm
I would like to repost the above link.  This work was done and produced an effect just like tesla did.  The plasma is a selfpinching plasma.  In other words it has a negative specific heat.  That means the more energy you introduce the less heat it has.    The plasma remains thermally cool.  This very construct is used by hot fusion scientists trying to pinch the plasma to the point of criticallity and the binding energy of the fused neuclides is released in the form of gamma radiation and various other particles.  What happened during this man's research on the spark gap is that he burnt out a megawatt plant.  The Tesla coil produces and can transmit pure dc.  If you can get your rf oscillator to transmit pure dc let me know cause you got what it takes.  The dc transmitted does not raise the voltage inside the generator causing it to fail because of insulation damage what it does do is it introduces dc in the cores of the transformers the generator is pumping into.  Transformers not loaded rely on the saturation parameters of the core so that they effectively choke current between lines.  The Tesla wave like the telluric waves that run in the Earth are dc currents therefore magnrtically saturate the cores like a magamp.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
a.king21
Quote from: sparks on June 24, 2012, 10:16:39 PM
Brilliant link:
T-1000
Quote from: jbignes5 on June 24, 2012, 07:48:48 PM
That is interesting point.
Just my oppininion on TK double ground connection - it can be swapped with high capacity capacitor and everything else should be same. The reactive current going on LC circuit is typically high and curent transformer can be applied there. Unless you manage to tap into Earth curents themselves somehow there is no particular reason to use Earth connection...
