T-1000
Quote from: Zeitmaschine on June 25, 2012, 12:50:34 PM
Therefore the task is: how to tell the electrons of the first 1A to entrain some more electrons (located in a nearby metal object) on their way to the lamps, so that the result is the required current of 2A?
It might be quite simple to answer but not so simple to do real thing:
With AC source you need resonant LC circuit atached in series so it would amplify voltage and curent in right circumstances. The idea is to let 1st impulse get accumulated in LC circuit then have it running in 180 degrees of AC source signal phase. So the second signal you generate would add to main signal and amplify its amplitude...
forest
Quote from: T-1000 on June 25, 2012, 12:56:37 PM
Indeed. If the lack of electrons would be the only reason for dim bulbs in Zeitmaschine example then attaching twice thicker wire would provide enough of them and this is what really happening but no matter how hard you try the missing amplitude cannot allow them to cooperate.
At least correct answer  ;D Resonance can be implemented in many ways.
Shokac
In theory the principle of work is easy: A power source which provides 220V 1A is connected to a lamp which requires 220V 1A. The lamp shines brightly.
Now connect a second lamp parallel to the first one which requires another 220V 1A. The result will be that both lamps are dim. What is the cause of this?
The cause is a lack of electrons! There are to less electrons coming from the power source to get a current of 220V 2A. The gate of the power source is to small (the internal resistance is to high) to allow more electrons to pass through.
Free electrons from air
Shokac
dole
Hi,
Last couple of weeks i was playing with ground transmission based on Tesla concept and defiantly, god ground is good conductor.
I am still playing with the concept, so I was thinking that maybe TK is hiding transmitters, only Turkey video shows transmitter and receiver,
other, green box and 2004 video shows only receivers.?
Anyway here is historical evidence nearly as TK mystery of those days.
I believe Nikola discovered magnification effect by the the earth transmition and announced possibilities of tapping earth current.
http://anengineersaspect.blogspot.se/2012/02/following-article-found-in-worlds.html
d.
By the way does anybody knows how Tesla connected 3 plate capacitor to his primary?
