0 Members and 60 Guests are viewing this topic.
wattsup
In the tent device, if those are capacitors, seems four series times three or one per phase of the motor. Those capacitors may be chosen to match the inductance of either the tower coil primaries but may also be a match for the inductance of the motor windings. The motor will have its own rather high inductance and create good flyback that those capacitors may be required to catch and re-deploy.
Actually, is that an AC or DC motor. Does it have slip ring or commutator. If it is using a commutator DC motor, then maybe the motor is being used as the main pulsing agent for the complete system and that is why it is run without a load. All they need is the motors' make/break and inductive flyback ability (if DC). Is it possible to have three DC lines slightly off phase to feed an AC motor? Should be very hard to do so in most likelihood that motor is DC.
I mean with so many capacitors in a bank, where is the switching? Where are the diodes if the caps are to hold a charge? Surely those caps were not designed to handle the highest voltage discharges of the tower coils. Inversely, if the caps were used to catch the highest tower coil outputs and those caps were feeding the motor, then as voltage rises in the caps with the high voltage reactive power, the caps condense that energy into a usable energy that the motor can use to keep turning and if the motor is also turning to provide the pulsing of the complete system then we can understand why the motor was turned first with outside means. Not only because of the very high start power factors involved but also to start the pulsing in the total system.
Nothing in that system is there by accident and all that is there may be more interdependent then we think.
As far as longitudinal waves (LW) are concerned, I have been slowly developing a very radical view of ether, energy, magnetism, magnetic fields, etc, and all that I know says there is no such thing as a LW in the sense that we see it is being described is a big mistake. One of many mistakes indeed.
Just a question as a teaser. A shark in the ocean can sense a drop of blood miles away from were it is located. So, did the blood create a LW that is sensed by the shark. Or, is the shark designed to sense "presence" without requiring any LW type effect. Presence is a word that is not being used in OU or EE but it could easily explain most all LW effects.
I could say so much more but am afraid that these more radical views would mix up guys that cannot think with a multitude of variables, since this is what you need to do all the time. Each time a factor is presented, you have to take that information and compare it to what you already know and see if it fits all the other variables. By doing that, then your critical mind will always be ready to analyze the immediate events and put those effects into a workable context. But if the base is just fed by rules and laws that are only really suppositions and this had been engrained inside your mind for so long, then your critical mind muscle is numbed down and cannot see that in reality, there are far more variables then what you have been taught. I could go on and on about this but will not.
Suffice to say that only by expanding your perspective of what is possible in nature will you be able to see and work and establish a new outcome. If you go by the same old rules, you will only produce the same old results.
For me right now it is a question of pulsing with the greatest flexibility possible to better see more effects that are impossible to see with regular fixed works. So what I did is hire a local top-notch EEer that will be building a pulse circuit to my requirements and hopefully soon I will be able to play more deeply with my toys. If the circuit works out well, I have asked the guy to also prepare a circuit diagram.
wattsup
PS: Another question. I don't think TK is using outside power. The fact is that TK lifestyle, probably no cable TV, he lives a more simple life then most of us G20 dwellers, more quiet, more time to THINK and analyze things more deeply then us, to see an effect that we are just blind to see ourselves. I had prepared many more posts but did not post them because of the thread orientation of LW seems off base. I do not want to send energy elsewhere. I want to make it where it is so for me LW is not an option.
Also a word to JB5. Don't let others dictate or influence your involvement. Although many of the points you bring I do not always agree with because you have a way of machine gunning though ideas, the simple fact that such ideas can be proposed and mulled over is a good thing. So thanks.
stivep
Quote from: Zeitmaschine on June 30, 2012, 11:20:30 AM
A motor in the tin can? This is an extraordinary idea. :D
Although there is no movement visible of the tin can due to inertia when the armature of the motor starts rotating. Seems I have to observe this more closely.
P.S.: What part in the patent description could be a motor?
look back into my long post I have added explanation for you
actually everyone who is interested might read long post again as I implemented so much in it recently.
Wesley
Сергей В.
Quote from: leo48 on June 30, 2012, 10:32:22 AM
File removed.. >:(   can I download this file on another mirror?. :D
Leo48
ПривеÑ, всем !!
No file is there. I made copy/paste mistake
http://ifolder.ru/31313689
Название: Основы сÑ,роения вещесÑ,ва Ð'олоÑ,овыÑ... 2010г.(665 сÑ,Ñ€.).djvu
Размещен: 2012-06-26 02:56:57
Ð"осÑ,упен до: 2012-07-26 06:54:34
Сергей В.
Something very very interesting. I think here is a "ETHERIC KEY" to unlimited energy conversion.
The question for all thinkers is: What Nikola Tesla had done to convert his High Frequency Current from his Magnifying Transformer to Low Frequency High Power current i.e. how he converted telluric current to ordinary ac-current 220V/50Hz or 120V/60 Hz ??
Here is a missing chapter 34 from Tesla’s Colorado Springs Notes published in TCBA NEWS (Volume 7, #3, 1988 pp. 13-15). (wll be fine if somebody grab a copy of Volume 7 TCBA NEWS from 1988)
Tesla’s Thoughts on Ball Lightning Production
Its import may be gotten form this brief quote attributed to Tesla:
    "...it became apparent that the fireballs resulted form the interaction of two frequencies, a stray higher frequency wave imposed on the lower frequency oscillations of the main circuit.... This condition acts as a trigger which may cause the total energy of the powerful longer wave to be discharged in a infinitesimally small interval of time and the proportionately tremendously great rate of energy movement which can't confine itself to the metal circuit and is released into surrounding space with inconceivable violence. It is but a step, from the learning how a high frequency current can explosively discharge a lower frequency current, to using the principle to design a system in which these explosions can be produced by intent."
Nikola Tesla
.... it became apparent that the conversion" "fireballs" resulted form the interaction of two frequencies, a stray higher frequency wave imposed on the lower frequency oscillations of the main circuit.... I think Kapanadze was doing just this. He rediscover Tesla effect. He was superimposed higher frequency on lower frequency or in other words mixed outputs of two oscillators. This condition is a main trigger of Tesla effect or Tesla conversion. In my opinion the key role here playing Standing waves. There exist two Standing waves,  the both are λ/4 of particular on high and low frequency oscillations. We have here together two secondary coils and one main primary or exciter coil for both secondary. Logically bigger high frequency coil have powerful longer standing wave from smaller coil which standing wave is naturally smaller in all aspects. It's seems to me like striking two Ocean longitudinal water waves (or compression waves) against each other !! The question is how we can do it on best way ??
We need to study process of discharge High potential to Low potential. In Tesla's case the both oscillators are high potential but one is higher.  Looking from this aspect it's quite understand why Kapanadze sparks in primary circuit are so quiet and low power. The question is which element can do conversion with extremely high efficiency. In my oppinion nor one solid state element have been used.
Maybe vacuum spark gap (variant power radio lamp like triode), maybe mercury spark gap (encapsulated), maybe rotary (motor) spark gap.  Another ideas which comes to my mind are direct conections of output terminals with high voltage capacitor(s) or maybe high voltahe choke(s).
Did somebody was doing such experiments with two secondary Tesla coils (for example smaller into bigger) or in any free geometry position ?? It will be fine to join me in  conversation at this topic !!
TESLA APPARATUS
Following Tesla’s instructions, we rewired our apparatus as two synchronously pulsed high power RF oscillators, the first at a frequency of 67 KHz and the second at 156 KHz (The exact frequencies aren’t critical).
The basis for the apparatus was first conceived and patented in 1897 by Nikola Tesla. The idea of using two oscillators in synchronism was also used by Tesla at the turn of the century in a patented primitive spread spectrum communication system. The apparatus can be seen in dozens of photographs and circuit diagrams in Tesla’s Colorado Springs Notes (referred to as CSN below). There have been many descriptions and analyses of Tesla’s oscillators.
The classic being the Oberbeck in 1895. However, all of these scientific and engineering descriptions fall short of a true description. It wasn’t until we applied slow wave transmission line theory and partial coherence to Tesla’s oscillator that we were able to accurately predict the operation of the oscillator and the subsequent production of fireballs. The apparatus consists primarily of two one-quarter wavelength, slow wave helical resonators above a conducting ground plane. Both of the resonators were magnetically coupled by a common link to a spark gap oscillator, of high peak power (approximately 70 KW), operating at a frequency of 67 KHz.
source:
http://www.bibliotecapleyades.net/tesla/esp_tesla_20.htm
leo48
Every problem has always at least two solutions simply find
The strength of the strong is the ability to navigate struggles with eye serene
