0 Members and 85 Guests are viewing this topic.
forest
Quote from: jbignes5 on July 03, 2012, 10:25:32 AM
Wait just because I can't understand him that means I didn't analyze them enough. Wow... Why do you have to be like that? If you got nothing to contribute why are you here?
I contributed more that you think  ??? Apparently nobody is listening here... In green box video there are two grounds but only one of them is connected , not both at the same time, compare to "aquarium box" video, still only one ground. Guy near water hose was annoyed but other one touching water faucet. Why ? He said " spokojno stoisz i ni kakich problemow niet" means probably "you are standing calm and no problems" then said "release" and that man is not touching faucet anymore. What is that telling you ?
Again : later in video Tariel assistant clearly said about comparision with power station and then performed experiement with turning off and on a bank of maybe 10 bulbs each 200W - no dimm reaction from the nearby bulbs laying among trees. He explained that such (scaled up) power drop on grid would cause catastrophic failuer if staff in power station would not accomodate power usage.
Again : when ground was changed to burried radiator only one bulb could be lit and what Tariel checked first ? Interesting...
Many such moments can be catch and even more if somebody could translate video from 2004 year - it contains very interesting detailed explanations I think
jbignes5
Quote from: forest on July 03, 2012, 12:47:54 PM
Thank you. I didn't know if you meant that in a different way, thats why I asked if you were serious... Agree there is plenty in the videos from the chatter going on there. Since I don't know his language at all I'm guessing because of gestures he makes and facial expressions. It not easy to do.
stivep
Quote from: dllabarre on July 03, 2012, 07:26:10 AM
Wesley (Stivep)
What is inside of Green Box?
What is inside of plastic box on top of 200 watt device?
DonL
sorry for responding late.
What is in green box, the same as  in BED presentation.
Even inverter was utilized in green  box from  BED    presentation.
what puzzle me is is it possible that in my presentation in Tbilisi that coil that was bigger in diameter................ was that possible that diameter was bigger because that was ceramic capacitor inside?   So TK made change
instead of showing like in aquarium two separate chokes  ( red and black) next to horizontal coil-capacitor he put everything together? so it looks like one  coil?
I remember when Guy with  the mustache   he got scared when I  wanted to look inside the coil.
And in did he destruct my attention.
What was inside the box...
good question..
If I was to be ,100% negative, skeptical and criticizing
,,,,,,,,,,,,,,,,,,,than  I would  think that in that plastic box......... it was very small  (alarm box type ) battery inside and I would think  that this is sort of real device, but not real device.
But calculation led me to conclusion that with the load of  200W  battery could not withstand .
Just by regular current calculation   the battery must hold 16.666 A for 30 minutes.
By that typical 12V 8AH battery would not be able to withhold it.I would see deterioration of the light with time. and at the minute 23 the battery must of  be completely discharged .
Definitively concept of TK was there,  he did not have motor so less energy consumption...
Electronic ignitor is very low current HV  device.
Wesley.
Farmhand
Quote from: sparks on July 03, 2012, 12:08:25 PM
    I guess it is the first video made at the place he was renting but TK buries a radiator with attached cable.  He is duplicating what Tesla did in Colorado springs when he was trying to build a lightning arrestor so when the secondary broke out it wouldnt kill people.  TK then takes a second wire and attaches it to a water main.  He asks someone to measure the difference.  The guy takes a voltage reading.  Tesla took resistance readings.  Tesla watered down his buried ground metals but the water would just run through the soil and the resistance between that and the watermain run out to his site would go up over three thousand ohms.  When Tesla was experimenting with his transformer corona discharge would back down the watermains and make pipes glow purple white.  Now when miles of pipe line glow purple white (uv also and xrays etc.)  are we to believe that all this energy is coming from a generator going out to Tesla's spot then returning on metal pipes and somehow majically jumping into the powerplant generator through the neutral back through the boost transformers in a closed loop circuit.  Could this be a local event CATALYZED by the amount of charge distributed in the ground CAPACITOR.   Tesla theorized about an energy sink.  This would be analogous to a chamber with attached tube in a lake.  As water flowed into the chamber it passed through turbines.  The turbines drove electrolysis units converting the water to hydrogen and oxygen which continually floated out of the chamber.  The chamber never filled up so the pressure differential continually was maintained.  A few years later he remarked about his earlier energy sink mind exercise and stated he was successful in creating one.
I've never heard of these miles of pipes glowing purple white. Can you provide a reference to this claim ?
Aren't the water pipes under the ground ?
How would one determine that miles of underground pipes are glowing purple white ?
Cheers
