0 Members and 115 Guests are viewing this topic.
jbignes5
 Yes there were plenty of times Tesla reported coils spontaneously ablaze with a white fire. Or every piece of metal in the entire building crackling with this energy. It seems he was the first to have a supercharged Exciter field. He also reported the ground was crackling with this energy the closer to the emitter and reported seeing this energy as someone walked over the ground. But you got to understand he was testing the near maximum field strength that the surrounding environment could handle. That was in the millions of volts if not much more.
He said that this was new territory because of his special transformer. It was the only way to force the voltage that high. That transformer I suspect is whats in those white boxes filled with oil. So you can see the amount of special transformers he had in Colorado. Someone called them caps but It has to be those transformers. They have 3 terminals and were filled with oil, that makes sense with them being those special transformers. One of the terminals is a common connection from the picture that was shown previously.
Zeitmaschine
Quote from: stivep on July 03, 2012, 03:52:27 PM
sorry for responding late.
What is in green box, the same as  in BED presentation.
Even inverter was utilized in green  box from  BED    presentation.
This means, don't use any electronic/electric parts/equipment which cannot be there in the 2004 tin can video, because it would not really contribute to the quest for free energy (at least in TK case).
What riddles me is the use of complete modules (by TK and others) obviously build out from old TV's or radios and such things. What module in a TV or a radio could be helpful in building a free energy device? Horizontal deflection? Vertical deflection? Audio amplifier? Tuner? Power supply? IMHO it would be much easier to tailor-made the FE circuits out of discrete electronic parts.
Quote from: Shokac on May 27, 2012, 11:01:03 AM
On secondary coil (power transformer) we have large capacitor for decrease our high frequency. In the output of the Turk device are powerful diodes. They fix output energy. Next step - it passes through a capacitor and then formed 50 Hz.
Hence another idea: Video Proof of Concept http://www.youtube.com/watch?v=Vko8pfnX_w0
What if we connect this circuit instead to an antenna to a Kapanadze/Tesla coil? Anyone tried this yet?  ::)
Quote from: Сергей Ð'. on July 02, 2012, 05:10:07 PM
Имя Ñ,,айла:
   Shock Images 2010.zip - 19.8 Mb
   http://oron.com/7539913xdbhv
from USA ARMY ARCHIVE !!
Now how to figure out which ones are real and which ones are photoshopped (so no one can find the ones that are real indeed).
But this one (little finger) most likely is real: http://www.google.com/search?q=Gregor+Sp%F6rri&tbm=isch
sparks
Quote from: jbignes5 on July 04, 2012, 07:01:38 AM
        Tesla designed his own capacitors.   They were multifiilar coils.  A single DC pulse into one of these coils would charge the capacitor to 250,000 times the input pulse voltage.   The impedance distributed in the coil/cap. No charged mass aka electrons flow in this circuit but electricity certainly does.  Electrons are slow to react whereas space which is positively charged has no problem moving.  There is more space inside the wire than anything else.  The electrons resist charge redistribution because of their motion.  When copper is cooled the resistance drops.  Because you dont have this chaotic charged mass movement problem.  Tesla experimented with cooling his primaries in liquid nitrogen.  Tesla knew Thompson was full of shit. So aren't these idiots claiming they are using Tesla transformers to put on spark displays.
    Lets try to rate one of these in standard faradic capacity.  The coil terminal voltage is say a million volts.  The charged mass not surface area mass is say 30 kilograms.. The weight of the conductors in a 1000 microfarad electrolytic capacitor is say a gram.  One gram times it's terminal voltage when fully charged before rupture of the dielectric is say 125 volts. Giving us 125 gram volts per .001 farads or .125gram volts per farad     Tesla's coil yields 3 times 10tothe10th gram volts divided by .125 gram volts per farad and you come out with  2.4 times 10 to the 10th farads.
   Put one of those puppies in a Pierce Arrow and drive all day long at considerable speeds.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
andrea76
Quote from: sparks on July 03, 2012, 12:08:25 PM
    I guess it is the first video made at the place he was renting but TK buries a radiator with attached cable.  He is duplicating what Tesla did in Colorado springs when he was trying to build a lightning arrestor so when the secondary broke out it wouldnt kill people.  TK then takes a second wire and attaches it to a water main.  He asks someone to measure the difference.  The guy takes a voltage reading.  Tesla took resistance readings.  Tesla watered down his buried ground metals but the water would just run through the soil and the resistance between that and the watermain run out to his site would go up over three thousand ohms.  When Tesla was experimenting with his transformer corona discharge would back down the watermains and make pipes glow purple white.  Now when miles of pipe line glow purple white (uv also and xrays etc.)  are we to believe that all this energy is coming from a generator going out to Tesla's spot then returning on metal pipes and somehow majically jumping into the powerplant generator through the neutral back through the boost transformers in a closed loop circuit.  Could this be a local event CATALYZED by the amount of charge distributed in the ground CAPACITOR.   Tesla theorized about an energy sink.  This would be analogous to a chamber with attached tube in a lake.  As water flowed into the chamber it passed through turbines.  The turbines drove electrolysis units converting the water to hydrogen and oxygen which continually floated out of the chamber.  The chamber never filled up so the pressure differential continually was maintained.  A few years later he remarked about his earlier energy sink mind exercise and stated he was successful in creating one.
probably the ground wire serves to discharge the static electricity generated by the conversion process. in the video below at min 11:28 when the tripolar wire is disconnected to the rotating system, and connected directly to the lamps , an static discharge occur..........http://www.youtube.com/watch?v=qVUN3GsekKQ&feature=fvwrel
anandml
Tesla transmitter and receiver circuit, may be TK made his free energy device based on this circuit
