0 Members and 94 Guests are viewing this topic.
sparks
What riddles me is the use of complete modules (by TK and others) obviously build out from old TV's or radios and such things. What module in a TV or a radio could be helpful in building a free energy device? Horizontal deflection? Vertical deflection? Audio amplifier? Tuner? Power supply? IMHO it would be much easier to tailor-made the FE circuits out of discrete electronic parts.
Flyback transformer and anode diode.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
jbignes5
Quote from: sparks on July 04, 2012, 01:36:11 PM
Well lets look at what he does have. bridge diode bank, two transistors, transformer, coil(Tesla style)/capacitor(Round) and an inverter with probably a capacitor or battery as power source or gas tank.. Oh an a lot of wiring. If using a cap you could charge it via a battery to kick start the oscillator and possibly a ground or virtual ground. Remember for a virtual ground we could use a voltage divider resistor pair just before the circuit and by all means that is what could have been the use of the other capacitor before the voltage divider.
Zeitmaschine
Is there one? I have not seen any hard evidence yet that TK uses a Flyback in any of his devices at all.
In the transparent box there is a chassis visible with three tube sockets (if I see this correctly). If there are actually radio tubes fitted in these sockets (can't see them) and they are functional then they need at least twenty seconds to heat up. But TK starts the device within one second. One of the tube sockets is covered with thermoplastic glue on the soldering side. But if the tubes are not working or not even there (because heat seems not a problem) then the whole chassis module is non-functioning. Hence what is this chassis for? Is it for beautification/distraction only? What the other modules are for? For the same reason?
jbignes5
Quote from: Zeitmaschine on July 04, 2012, 08:30:45 PM
There is no reason he wasn't running them in cold cathode mode. This is mostly pure voltage and not current based. The other video shows all the main components of transformer and the list I mentioned earlier. The newer versions look like a more solid state versions like the other box version in the house.
