0 Members and 379 Guests are viewing this topic.
frantz
Quote from: Zeitmaschine on July 06, 2012, 09:50:25 PM
The Secret of Electrical Free Energy, (C) 1982 T. E. Bearden
http://www.cheniere.org/books/newteslaem/p12.htm
Thirty years have passed since publication (which sounds like a description of TK device) and although I'm in no hurry an inner voice tells me it's now time to get finally a grip on this.
Zeitmaschine,
very good document. Maybe there are not contained scheme of device...., but we can try to understand what from we have "additional" energy.
Thanks a lot.
@All
you should read 4 pages from Zeitmaschine link for good understanding.
Again Thanx.
Frantz
frantz
sparks
  Neuclear magnetic imaging is wonderful.  However this  system uses photon scattering effects.  The photons don't come for free.  A small portion of the photons introduced in the mri field are frequency shifted by I believe it is Compton inverse scattering..   This is when photons are absorbed by matter and radiated by matter at a higher frequency than when they were absorbed.  Antennae tuned vary exactly to the input blue shifted frequency receive the data from the reflected signal at various geometric locations relative to the photon emitter and input to a computer to show motion of the fluids in a person relative to the photon input.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
anandml
 The fact is that with this inclusion of transformers, with a spark discharge on the output winding of the second transformer, the light really starts to shine brighter, but exactly that is the amount of power, which is summed up by an additional high-voltage power supply, nothing more to be there just could not. And many are tied to the principle of operation, long bogged down in unnecessary studies coup domains. Then a conclusion is, it just does not understand it with the principle of operation, hastened to make everything in the world, having taught that energy is released from a ferromagnetic material.
Well, go to the last topic: Appointment to the installation of iron, the two output power transistors and a second winding beneath the spiral resonator.
Thus the basic condition of the standing wave is the equality of frequencies, such is always realized when we have the incident and reflected waves. The observer, placing the current node is an indicator (measurement frame), states that the energy flow in the longitudinal direction is absent. For us, this means that the rate of energy flow, and relative to the observer, and on the wave medium (air) is equal to zero. But as you can see, this is the first process that starts the creation of a standing wave with the maximum energy along the grounding cable (the first switch-to-install Kapanadze). But in a stationary position of the nodes and antinodes, as you know, take off the energy of the surrounding space is impossible. That, and for this we need a second process - the organization of the movement of these nodes and antinodes in the longitudinal direction along the grounding cable  to any desired frequency we (the second switch-to-install Kapanadze), it is possible to apply only in the spatial resonators (lines with distributed parameters). To organize this process analyze an example. The process of movement of the standing wave is well illustrated in rhythmodynamics Ivanova N, probably give you an example:
Consider the behavior of the standing wave and the rest spaced sources in the environment. In the interval between the coherent sources of standing waves formed package. The phase shift between the sources available. In this situation, the interference pattern will be symmetrical. Note the position of the central loop.
Create a phase shift between the oscillations. It is obvious that the position of nodes and antinodes will move relative to the initial position. With increasing phase displacement nodes and antinodes of the standing wave move further and further from its original position, and with phase shift of 180 ° are shifted by half the length of a standing wave. Further increase of the phase shift will lead to further displacement of the standing wave.
Phase shift leads to a displacement antinodes and nodes.
If, by definition, is characterized by the absence of a standing wave in the space of energy transfer, we are changing the phase shift, such a transfer arranged: a change of phase shift between sources has led to the transfer of energy in the spatial interval between these sources. Time varying phase shift between the sources, there is a difference between the frequencies. This means that the availability of sources of frequency difference leads to the transfer of a prisoner in a standing wave energy in the direction of the source of the higher frequency to lower frequency source. Transfer takes place (current) energy.
Now back to installing Kapanadze, we see that the source (spiral resonator) we have one and the reflected wave from the ground, meeting with a traveling wave from the source resulting in a standing wave. But here we can see that the reflected wave comes back with a time delay, and during that time we have an opportunity to change the length of a traveling wave. And here we can recall a passage from izoteriki Kryon of displacement distance in the time circuits. Since the meeting two waves of different lengths, the result of the addition will be in the form of the displacement distance of the standing wave, and this is exactly what we need. And as easy to guess, we need to change this time one of the parameters of the spiral cavity or vessel, or inductance. However, the capacity can not imagine the possibility of how to do it electrically, mechanically possible, but I think this design is an open door to anyone not like it, but to change the inductance of the electrical method can be used without problems. Here we have for this and placed a coiled sausage ferrite resonator. As we know, the ferromagnetic material has a parameter called the relative magnetic permeability, which may vary under the influence of external magnetic field, the so-called magnetization. And here we have suggests to install the following winding, magnetizing, which changes the resonant frequency of the spiral resonator, we call this the winding of the modulation. And depending on that frequency, which is served on this winding, the output winding emf is induced at the same frequency, equal to the frequency modulation, which most be for example equal to 400 Hz, output power will not change. We look at the final constructs.
Modulation coil again showed a single layer. In reality it will depend on the type of ferrite, the current flowing through the coil, and the size of the ferrite rings themselves. But a couple of dozen turns the entire length of the ferrite sausage can be wound safely. Further, this winding is connected to output full-wave sine wave (if you want to output a sine, which form modulate, so get out) cascade current generator, the generator can be collected as you like, schemes on the Internet and in any literature is full, there's no point in it lead. Current generator is enough to collect on the magnitude of the current 2.3 amps. The output transistors are warm, so they sadist on heat sinks. And it is very important! As the modulation coil is in the same plane with a spiral cavity, then it will also be induced emf and the high frequency so as not to shunt high-frequency free vibrations of these resonant elements of the system through the power generator 50 Hz, it is necessary to provide isolation for high frequency, such as installing a chain choke coil modulation par a couple of hundred uH (in the diagram is listed as a choke), and better throttle in each wire. Now we can easily control the inductance of the spiral resonator with a low frequency of 50Hz with no bypass high frequency oscillations. But the question is solved in a classical way, meaning to talk about it I do not see, it all depends on your wishes for the management and control.
