0 Members and 64 Guests are viewing this topic.
Ganzha
I think Kapanadze used too much fake parts in his real works devices/ He shows not connected wires and fakes cols, fakes sparks and ground cables
One men fom Ukraine aka Victor 55 years radio amateur explains a lot of that  he speaks here
http://yadisk.cc/d/M3nnwN2UyhH
sorry it is russian languge only... but I am sure that Vesley would call him and would makes Englich version of this extremly new and absolutely brilliant theory of getting Zero point energy
here is schematics
main idea is  to drive electrons t crazy energy  in cuprum coils with current 6050 hz by ANY inductions heater. Ferrite core is a power amplifyer some kinda mirror to heater frequency 10 ////130 Khz
All other devices in Kapanadze shows are FAKE
Ganzha
schematics diagram of Victor's from Ukraine Kapnadze replica
Ganzha
Vicrors idea is Power  Amplifyer and
Tyger to be successfull should use more power from HV generator and add more windings for heater (he used only one loop over ferrite cores.
The second he should connect  50 60 herz source direct into output / load coil
captainkt
Hi all, tried induction heater about a year ago and had no luck blew the heater up along with lots of other coils and bits. However saw the latest circuit went out to Aldi and bought another heater, very quickly put a coil over heater to bulb and earth no joy. I then used a piece of coax cable about 30 ft connected a 60 watt bulb to earth and 240 volt through a variac, turned up voltage so that bulb only dim. Switched on induction heater and bulb lights brightly, moving coil over hot plate makes bulb go dim or bright. Lots of room for experimentation now. Will keep you informed as this is first time with so many different coils and set ups I have combined two frequencies with visible results.
Keith
Zeitmaschine
Quote from: Ganzha on July 18, 2012, 01:15:25 PM
here is schematics
Real Kapanadze? The power of the induction heater is specified with 100 to 800 watts on 12 volts? Where does this (initial) power come from?
I would estimate the transformer in the 2004 video to a max. of 5 amps with 12 volts, that equals 60 watts. The ammeter in green box video is heavily fluctuating but shows around 0.4 amps input power. That is 220 volts × 0.4 amps = 88 watts power consumption.
This calculates to no more than 44 watts of heat dissipation for each of the transistors on the heat sinks. Thus I am a little bit suspicious why the cooling fan on green box is needed at all, it worked without a fan in 2004 video, furthermore no Hi-Fi amplifier with 100W output needs a cooling fan. In addition the loading capacity of the light blue box inverter is rated a max. of 400 watts.
Hence something must be wrong here.
