0 Members and 188 Guests are viewing this topic.
forest
I think stiveip statement about motor in round box in 2004 year video has merit. Green box video run on two transistors probably KT805 or similiar Russian versions (because SR913 used them also , there must be a "leakagge" of info) they will heat on switching 100W of power.
sparks
I would suggest that a spark gap is a thermal to electrical conversion device.  Tesla the inventor of the process Kapandenze admiitedly replicated found out that the spark gap Physical location is important relative to his primaries.  The reason this is important is because the primary is an antennae for the oscillations emitted by the spark gap.  The spark gap converts heat into coherent electromagnetic waves.  The electromagnetic waves are then captured on antennae designed to create a standing wave whose 1/4wave stands on terminals where highvoltage develops between node and antinode of the standing waves.  Voltage is a result of different charge densities PERIOD.  It does not rely on any massive particles we call electrons to move.   An electromagnetic wave in space is said to produce a current.  There are no electrons in space to move therefore we see that the current will flow between two places in space of unequal charge densities whose instantaneous values are changing.  Electromagnetic waves are produced when you have a timevarying distribution of charge.  Tesla waves are produced when you have a non time varying charge density maintained.  They produce an electrical monopole  and a magnetic field of great dimension as the magnetic and electric field is one in the same.  Of course if you move your monopole you will produce an electromagnetic wave as you now have a timevarying charging of the space your monopole moves through.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
verpies
Quote from: Zeitmaschine on July 19, 2012, 11:00:42 AM
That is 220 volts × 0.4 amps = 88 watts power consumption.
That calculation is invalid for non-DC waveforms.
Even more so when the volts and amps are measured by low frequency meters, see:
http://youtu.be/iHcl-85baHs
http://youtu.be/hvGGtvkEaIo
http://blazelabs.com/e-exp09.asp
This is not a trivial power calculation error - it can easily achieve 900%
stivep
Quote from: sparks on July 19, 2012, 01:51:15 PM
You have got me  Enlightened
Why in the world I did not think ..... or was I............
The key  is in  tuning..........
Lets take:
Standing wave is between point A and point B  for single resonance of single frequency of it.
Now lets take any two point and adjust the maximum frequency of oscillating string by.......
changing the distance between two points.
Yes mechanically nobody  do it, because in practice is inconvenient........and difficult task.
Usually, when we play with wave  we keep the distance of two points the same..
These two children.. holding ....jumping-rope holding in hands end of the rope .
So the distance between single  say vertical ( or horizontal) wire where ground is point A and end of it is point B of an antenna.
That determines resonant  of that wire.
With most of proposed explanation that includes an antenna (as  part of circuitry),we tend to
adjust property of the circuit  by LC using  capacitor....
In  dealing with  Longitudinal Wave we have no  transverse wave   properties.
So LW has length as a property and time of travel from A to B as e property.
The compression wave is a mechanically LW.
So electrically we may use analogy to mechanical wave.
Can than we use capacitor to tune this piece of wire to  resonance with spark gap dominating frequency or
spark gap frequency of interest.
Can we or we cant... We are not dealing with transversal wave or if we are dealing than we  are dealing with  possibly interaction of  LW to EM wave...
That is extremely intriguing..
So many times I have heard
Think simple
Should secret of TK be............
Distance between  end of an antenna and ground with respect to spark as a spectral frequency inducer?
Should all of that be so simple?
Just to play with this and  with placement of spark gap?
Position of spark gap  with respect to antenna gives us factor of influence  between two of them.
But than was it that Tesla (concept of TK acquiring Tesla concept) discover just that?
Now everything seems to be much simpler.
If we are looking  for energy transfer  and/or earth ( ground) contribution......( electron flow)
If we are looking for energy origination ( as reservoir ) than the ground ( the earth) is major undeniable participator in the circuit .
Earth than is purposely implemented to the circuitry by means of permanent interaction
Than you look at Eric Dollard videos
Than you analyze what he says about Marconi  (1 billion  dollars on today's money) investment in California.
Was Marconi delusional?
or
Was Marconi genius?
or
Was 100% sure prior to investment  that what he is building is WORKING !!
Because he has checked  in mini scale models that it in did work.
His knowledge comes from Tesla.
Did he witness Tesla experiments and he perfected them to the point that investing so much in California was to be 100% success ?
The major difference Between Tesla and Marconi is that Marconi was businessman.
No businessman invest all of his money and money of other partners( investors) into the project that does not work..
So  in 1919 Government "created" RCA.
RCA was able to build the building on the therein occupied by Marconi just to spy on Marconi.
Government was in fear..
Marconi was about to become God.
Misbehavior  of any power, any government in the world could by punished by Marconi- the God
who simply switches off power to say Asia or Europe.
In his California plant Marconi build 3 antennas
1 on Asia
1 on Europe.
1 on Australia
In approx 1921 Government SHOT DOWN Marconi  project.
The Tesla Marconi Wireless System
a. explanation  and presentation of place where  Marconi Longitudinal Wave power station once stood and reminding fragments of it.
b. LITERATURE AND SOURCE ATTACHED TO THIS  PLACE
c. theory  and practical apparatus schematic of  above.
d.Political pressure and decisions leading to confiscation of site and closure of facility.
e.analysis of the structure and its basic functions .
http://www.youtube.com/watch?list=ULUGOTJ0SZN70&feature=endscreen&NR=1&v=bUFaSGg_efY
additional material for education  only
Not directly explaining  what was said above but important to know.
TESLA'S BIG MISTAKE?Sept 1999 William Beatyhttp://amasci.com/tesla/tmistk.html
some of Erick Dollard papers:
Introduction to [/size]DIELECTRICITY AND CAPACITANCE by Eric Dollard
http://www.borderlands.com/dollardandtesla.htm
Summary of conclusion:
Longitudinal wave properties:
It is Compression torsion wave
Forms artificial tube or waveguide
Magnetic and/or electrical in nature.
Wave by definition is  a state of motion therefore is not static and is energy conversion participant.
Electrostatics is a key component.
Advanced Energy Weapons utilize LW. as is directional. acts as concentration of energy medium so Schumann effect phenomena  is to be applied.
Therefore as if beam is directed to particular  object it might  target any building in the earth "at no time"
Pipe like structure, might also be used as transporting medium for other means of AEW.
Both Transverse and longitudinal waves interaction is conformed .  http://adsabs.harvard.edu/full/1996A%26A...312..691N
Mentioned above might put new light on some very much controversial events leading to mass murder of innocent people.
http://journal.borderlands.com/1987/the-fallacy-of-conductors/
Eric Dollard 2007  Misconceptions of Electricity and MorePLEASE LOOK FROM 0:49:50 MINUTETO SEE ESSENTIAL PART OF IT. http://www.youtube.com/watch?v=GObB67ETvRQ
http://www.sciencedirect.com/science/article/pii/0304388689900478
Electrodynamic reactions of a charged single lycopodium particle in the field of an electric curtain of the plane type with a standing wave was experimentally studied. The path of oscillation of particle by changing the value of the voltage was analysed in detail. It was searched in which way the trajectory of oscillation of a particle changes by changing the value of the supplied voltage. These investigations were carried out with the purpose of determining experimentally the boundary conditions at which a particle is stopped within the system or released from the electric curtain. Special attention was devoted to those particles which constantly oscillate at cylindrical electrodes. This type of curtain is especially suited for designed particle feeders, electroseparators and band-pass filters. The electric curtain can be used to separate two kinds of mineral particles or as a selective electrostatic filter.
look at other  6 parts of it
1.[/font]Part 1 of 6: Eric Dollard Tesla Longitudinal wave Energy SBARC Ham Radio with Chris Carson
a.history and introduction of electromagnetic  longitudinal waves.
b. differentiation between various waves by its origin and its type.
c. mathematical properties of calculation and  descriptive properties.
http://www.youtube.com/watch?v=YhuSn6sc7sc&feature=channel&list=UL
2.
Part 2 of 6: Eric Dollard Tesla Longitudinal Wave Energy SBARC Ham Radio with Chris Carson
a. basic  differences between  transvesal and longitudinal waves ( sine, square, pulse)
    at this point  we have assignment to LW as DC based.
b.Presentation of practical device utilizing LW and explanation (  basic elements and modules.)
c.Eric practical algebra and formulas attached to math of LW.
d. impedance, wavelengths and properties of ground part of apparatus.
e. at minute 8:50 fundamental parameters of LW, and differentiation to  transvesal wave
http://www.youtube.com/watch?v=64yKW9FSsBY&feature=channel&list=UL
3.  Part 3 of 6: Eric Dollard Tesla Longitudinal Wave Energy SBARC Ham Radio with Chris Carson
a.continuation scientific support data
b. back to the table with practical apparatus.
c. controversy over sun light
4.
Part 4 of 6: Eric Dollard & Chris Carson Tesla Longitudinal Wave Energy SBARC Ham Radio
a. Chris Carson controversy over transformer
http://www.youtube.com/watch?v=6lqMiZPO9TM&feature=channel&list=UL
5.
Part 5 of 6: Eric Dollard & Chris Carson Tesla Longitudinal Wave Energy SBARC Ham Radio
a. short speech of Chris Carson
b. Eric Dollard  minute 5:16  controversy over sun light
c. Repression from government and local AUTHORITIES  to Eric Dollard and Borderland
confiscations, evictions, discrimination and so on
http://www.youtube.com/watch?v=XsrbaCJo3Qw&feature=channel&list=UL
Weley's experience:
Some who knows will understand what is going on.
QuoteThis is how it goes DICK ,"You right  or wrong "they" going to get you  just for being different."
So I understood recent attack on me on the tech-net at first hour of it by unidentified  dog  that can only  bark from his hiding place and bite when  it is a chance for it.
This is my reality.
6.
Part 6 of 6: Eric Dollard & Chris Carson Tesla Longitudinal Wave Energy SBARC Ham Radio
a. Questions form audience:
http://www.youtube.com/watch?v=vwu8rspxQWE&feature=channel&list=UL
7. Eric Dollard (1988)
Longitudinal Waveshttp://www.youtube.com/watch?v=aLAB-d8VnZ8&feature=BFa&list=PLF71B362214423F9D
Light is electromagnetic wave  too.Super-resolution and non-diffraction longitudinal polarized beamhttp://arxiv.org/ftp/arxiv/papers/0709/0709.2748.pdf
longitudinal field has many attractive applications, e.g. in particle acceleration [2, 6, 7, 13], fluorescent imaging [14], second harmonic generation [15-17] and Raman spectroscopy [18]. It can permit the achievement of higher resolution in  zpolarized confocal fluorescence microscopy [19] and scattering scanning near-field optical microscopy [20].    The longitudinal field can be suppressed or enhanced by amplitude, polarization and phase modulation of the incident beam [21]. For example, a longitudinal field can
be completely suppressed in an azimuthally polarized
beam
Eric Dollard Peter Lindemann Tesla's Longitudinal Electricity
http://www.youtube.com/watch?feature=endscreen&NR=1&v=Y4m82cvThd8
Conversion of the Vacuum-energy
of electromagnetic zero point oscillations
into Classical Mechanical Energy http://www.gsjournal.net/old/physics/turtur1e.pdf[/size]
Magnets and magnetic field interaction:
The contradiction with Carnot’s principle is analyzed.
http://www.new-energy-paces.com/brevet_anglais/pages_anglais/page/page4.htm
Shumann effect:
Marcos Dancing Magnets
short clip about magnets being pulsed at diffrent frequencys. watch them resonate @ 7.8 hz. for more info visit magnets being pulsed at different frequencys. watch them resonate @ 7.8 hz.
http://video.google.es/videoplay?docid=5540717206741162529&q=marcos+magnets
magnetic field on aluminum
http://www.youtube.com/watch?feature=endscreen&NR=1&v=a0YCTwWvykw
question:
Why eddy current behaves this way.
concentrate on  3rd magnet
Neodymium Magnet High Voltage Rotating Spark, arc, plasma
http://www.youtube.com/watch?v=UMJ3eCHZtGY
The reason for this video is only question
Why lightning is concentrated near Volcanoes?
Why clear acrylic when strike   with nail on the edge is releasing lightning inside its structure .?
UNLIMITED FREE ENERGY- LIGHTNING
http://www.youtube.com/watch?v=FZcUnpamk-w&list=UUX3maMjzIc6AzF2CJVZ4BrA&index=0&feature=plcp
[size=1.8333em]Spark in spiral magnetic field
http://www.youtube.com/watch?v=FrGtPKBXkVQ
Magnetic Levitation over copper
http://www.youtube.com/watch?feature=fvwp&NR=1&v=KXNELXRaBc4
Diamagnetically stabilized levitation over copper
http://www.youtube.com/watch?v=fMyPQ3UjY7o
his video demonstrates the diamagnetically stabilized levitation over copper. A large lifter magnet (not visible) attracts the tiny 1x1x1mm NdFeB N52 cube magnet. At this small scale and due the field geometry of the larger lifter magnet the weak diamagnetism of copper is sufficient for holding the tiny cube magnet in a stable levitation position. Be aware that this is not an eddy current levitation but diamagnetically stabilized levitation. The levitation is free and stable and needs no energy input. What you can see is of course eddy current damping when one trys to misalign the floating magnet. The levitation height is only about 0.3 mm. The match head is for size comparison. More stuff at http://www.innomats.com or http://blog.innomats.de
Wesley
Zeitmaschine
Quote from: verpies on July 20, 2012, 06:30:07 AM
Due to non-DC waveform the displayed value of 0.42A could be even too high. In tent presentation the AC power comes directly from the grid (I presume) and it consumes 200mA. That's merely 44 watts input power for a 3-phase device with a output of a few hundred amps.
In 2004 tin can video the device runs for 70 seconds continuously without a fan and nobody cares even slightly about transistor heating. Could be the heat sinks are not for cooling but to have something to attach the TO-3 transistors on.
Quote from: stivep on July 20, 2012, 07:24:29 AM
Lets take:
How does a (possible) motor in tin can fit into this theory? And why is it I have never seen Kapanadze tuning anything (actually the device looks tuned with a sledgehammer)? ::)
