0 Members and 177 Guests are viewing this topic.
Zeitmaschine
Quote from: forest on July 23, 2012, 04:18:47 PM
Do you have clear English translation of this Russian document ?
Not that I am aware of. This would be much too easy. :(
But the logical point is: If a coil configuration can produce electric energy, then it can produce also its own high voltage feedback. If a coil configuration cannot produce electric energy, then supplying high voltage from outside may not be much of a help either.
Quote from: stivep on July 23, 2012, 05:11:53 PM
http://presscore.ca/2011/?p=5279
There is an image that shows a part labeled »VIBRATOR«. But this has surely nothing to do with the humming sound in Kapanadze videos, hasn't it?
Edit:
My next idea #3: The switch on the tin can is 0n-0ff-0n. In one on-position a capacitor is loaded from supply, in second on-position the capacitor is discharge into the coil in order to get it started. In 2004 Video at 18.35 it takes a few tries to switch the lamps OFF.
forest
Toogle switch was something I considered important also, but I didn't found resonable explanation.
Another strange thing is flat copper strip attached to the cover of box.
cheappower2012
@Zeitmaschine,bravo,you reached the same conclusion ,about the starting up of the 2004 TK device.
In addition you require a run circuit other wise you will not continue running,the clue of
what that is comes from some experiments that I did.If you analyze the sound when the device was unplugged you find that
the frequency varies from 50/60 Hz to 400Hz as its dying,my first thought there must be a 50 Hz /60Hz generator in the can.
Most oscillators are stable with voltage changes except for a blocking oscillator,I experimented with that no luck,
I think that when its in a run mode there is a capacitor effectively across a power transformer
in the can,the inductance of the transformer and the capacitor forms a parallel resonant circuit at around 400 Hz,when the power
is cut there a tendency to oscillate at this frequency for a brief time.The purpose of the capacitor is to
cause an interaction between the coil in the EM field and the back coil to continue the effect.You get a very quick snap
if a good size capacitor discharges in a coil.This creates for a brief moment a very power field ,that also interacts with the space,however in my view ,you have to continually,cause the field to change
to maintain the effect althu not as strong as when starting.In my view you set the potential in this 2004 TK device, the potential is set by the transformer 220 vac,fed by the inverter.I believe you have an amplification of current,
energy is extracted from the space and transferred to the electrons.
This direction I think is simple and maybe correct,consistent with the
theory that its a simple device,Its not a Tesla invention.
vrsk
I have tried to built Don Smith's device of Reverse Tesla, but failed, in fact I have followed the theory for coil winding on aircore, Ref to the video.
http://www.youtube.com/watch?v=ldw-v0vEsdk
http://www.youtube.com/watch?v=ldw-v0vEsdk&feature=player_detailpage
Anybody Please help me resolve the issue..  8)
Thanks
Ravi
Zeitmaschine
Just my two cents: TK talks about »keeping resonance«. If this makes sense then the (Tesla) coil's primary and secondary should be in resonance to each other. If this self-resonance is the key for catching electric energy from the environment (can't imagine otherwise), then such a coil (once started) should be able to sustain a high voltage spark without an external power supply (like 220V/50Hz). Therefore in a first step construct a coil that maintains a spark by itself. In a second step connect some load to it in order to make use of the excess energy. If the coil can't even maintain a small spark without an additional power supply then there is surely no excess energy anywhere in the coil.
And that's my problem on p. 803, screenshot of oscilloscope. Because I had created the high voltage externally with a coil on a ferrite core (200KHz inverter transformer) it could never resonate with my air coil (2.4MHz) in a useful manner. Hence the air coil itself has to be the source of the high voltage, then there should accrue automatic resonance without the need of any (impossible) adjustment.
