0 Members and 532 Guests are viewing this topic.
Collapsingfield
@Captainkt, good luck and experimenting. Just a little hint: sometimes there is no big difference in the power at the inductions plate! When you see the power scale (1-10) you will use more then 1000W at 1 and about 1800W at 10. The plate is working all time with high power, then it is switched on-off periodiacaly when you use temperature, or other scale to control. The simplest way to measure the real input power is the using of a cheap power (consumption) meter on the line side. The output power can be estimated on other way, the simplest is the comparing the light intensity of  the bulb at 230/110V powered version. If there is big diff, than the output can signifinactly lower then the nominal value of the bulb!
Collapsingfield
captainkt
@Collapsingfield, thanks for that info will do that. What you are saying is that when the heater plate is saying 200 400 600 ------- 1800 watts etc this may not be so.
Keith
anandml
Please post some website address or links for thermal related projects or thermal energy is converted into electrical energy based type projects......
regards
anandml
frankidel
Quote from: Ganzha on July 30, 2012, 10:20:27 AM
Tariel shows a  copy of Teslas patent for some reason/// One of there is to keep secret of TK devices, Tesla! Tesla! Is some kinda magician words kinda Abracadabra!!!!!
He put a lotof old junk inside his aquarium to hidden his main secret, it doesnt matter what he talkig about////if you expect to get a details about his devices...... you.... should be......very clever person..... be happy then!
He shows too, the Linde Condenser, or maybe heat exchanger....
energia9
nearly all of you guys are going in the wrong direction.!
im liking those who are on the simple side.
dont listen to me im a government agent ..:)
