0 Members and 572 Guests are viewing this topic.
anandml
Quote from: e2matrix on August 01, 2012, 03:35:46 PM
You might want to keep an eye on this one - late September may be big news.  www.quentron.com
Thanks matrix.... if u know pls post some more thermal related project websites
leo48
Translate to english:
железная пласÑ,ина=  steel plate
плоская каÑ,ушка= disc coil
свернуÑ,ый коаксиал=folded coaxial
индукÑ,ор плиÑ,ки=inducer of tile
Leo48
Every problem has always at least two solutions simply find
The strength of the strong is the ability to navigate struggles with eye serene
Tito L. Oracion
Quote from: Ganzha on July 30, 2012, 08:23:14 PM
What I am telling! TK is Illusionist he make fools from most of us showing  never connected wires, sparks, talking about Tesla, but.. using just induction heater in his green boxes..... Green colos should motivated us to pay him "a lot of money"
http://youtu.be/PyeWRd7ZEBs
hmmmmmmm!
thermocouple:  http://en.wikipedia.org/wiki/Thermocouple
http://www.ferrotec.com/technology/thermoelectric/thermalRef01/
A triode again? its like back to basic again  ;D
i think your right?  :o
electrons becomes wild when heated plus some energy from other source then will gain gain  :D
in solar energy we get electricity from heated materials hmmmmmmmmmm!
very clever  >:(
i think i got another thing to scruitinize here again, lets give it a try buddies its not bad hmmmmmm.  8)
Therefore i conclude  a voltage plus a heated material give an equal proportion or more of the  current on the voltage made. hmmmm not bad buddies.  ???
case close. cheers  ;)
goodluck  ;)
;D
Jack Noskills
I am polluting threads, but take a look what I (re)discovered recently:
http://www.overunity.com/12487/simple-to-build-isolation-transformer-that-consumes-less-power-than-it-gives-out
This simple circuit takes power without affecting source which is the key to OU. It needs the pressure from source but source is not used. This circuit is always in resonance because there is no magnetic coupling to source, it needs only one frequency, no spark gaps, no diodes, no ground connection and no caps. Idea is simple: reach high impedance state that blocks current flow and then use bucking coils to harvest it. For me this works at grid frequency but I dont have gear to try it at higher frequencies. I have put untested ideas how to debug this thing further in page 12, input has to be sine wave. If you have ferrite and signal gen then you really should take a look, it is a few hour project atmost.
a.king21
Quote from: forest on August 01, 2012, 04:04:17 PM
Zeitmachine
Nothing if left from your comment.Wandering in opposite direction rather then assuming that Tariel is honest person. If somebody could translate videos much more knowledge could be gained.
I believe zeitmachine is quite right. I tried to tell folks a long time ago that the spark gap's only function was to limit the output power.
Here's what we know:
The device is very light.
There are no advanced electronics about anywhere. All early 20th century stuff.
Take away the plexi glass from the aquarium video and the junk components and there's no "weight" left  for a heavy trafo.
In Tariel's 2004 video (full version) he shows two containers full of experimental metal cores and several metal working hammers and associated tools.  What do you think he was up to?
The nearest I can get to perpetual motion is Ed Leedskanlin. He showed us a metal core with two coils which was in perpetual
motion and proved it.
I suspect TK messed about with this setup and got it.
There never was any Tesla high power stuff.
The other witness is Magnacoaster.
He messed about with a similar setup and got it.
I suspect a toroid or triangular version of a toroid or a semicircular core at the centre of his devices.
Why else would he need metal working tools? It's possible he also modified a light trafo and created a meg.
The lightness may also be due to a high voltage trafo being modified.
Maybe two trafos wired up wrongly with a second metal core.
The rest is just smoke and mirrors.
I hope I've pointed us all in the right direction.
