0 Members and 192 Guests are viewing this topic.
Tito L. Oracion
no! ???
i think the key to OU is heater  8)
a source of the current is different from the source of voltage hmmmmmmm  ::)  seems right  :)
in voltage regulator or AVR , the source of current is different module  is it not  bro?  ;)   8)
its like in gray tube, it has its source of current hmmmmmmmm.  >:(
see were not just just, we are thinking hmmmmmmmmmmm  :P
;D
forest
does induction heater produce AC or rather pulsed DC ?
forest
Quote from: a.king21 on August 02, 2012, 04:43:17 AM
I believe zeitmachine is quite right. I tried to tell folks a long time ago that the spark gap's only function was to limit the output power.
Here's what we know:
The device is very light.
There are no advanced electronics about anywhere. All early 20th century stuff.
Take away the plexi glass from the aquarium video and the junk components and there's no "weight" left  for a heavy trafo.
In Tariel's 2004 video (full version) he shows two containers full of experimental metal cores and several metal working hammers and associated tools.  What do you think he was up to?
The nearest I can get to perpetual motion is Ed Leedskanlin. He showed us a metal core with two coils which was in perpetual
motion and proved it.
I suspect TK messed about with this setup and got it.
There never was any Tesla high power stuff.
The other witness is Magnacoaster.
He messed about with a similar setup and got it.
I suspect a toroid or triangular version of a toroid or a semicircular core at the centre of his devices.
Why else would he need metal working tools? It's possible he also modified a light trafo and created a meg.
The lightness may also be due to a high voltage trafo being modified.
Maybe two trafos wired up wrongly with a second metal core.
The rest is just smoke and mirrors.
I hope I've pointed us all in the right direction.
I think the only way is to analyse 2004 video and assume that everything here is required for operation of device.
Next important thing is to consider where is the output connected then  why is spark gap used.
I agree that works similiar to induction heater but it's definately not, simply - after a few minutes everything would burn. So please think about the induction heater and the slight change to make it generate current not heat.
frantz
Hi @all,
I can not to understand how do you want to receive aplified current on output from the heater.
If we have connected (on output) in series : inverter (first connector, like a 220v voltage source), chock, load, chock and again inverter (second connector).
At this point, if we have real current gain, we have gaining current in inverter, too. What happen with inverter, will burn, like in FreeEnargyInfo experiment.
We should to create some loop on output by f.ex. capacitor pararelly connected to inverter. Capacitor should be taken which on short circuit will have correct current like 23A (in mF for low frequency like 50Hz).
Two chocks and this capacitor will work like pararell resonant (similar to resonant) circuit. At this point we should to tune magnetic field from "heater" circuit (by current) to corect value which is required to receive resonance (not real resonance but we create envrimoment which is similar to resonance for output circuit) on output.
One thing what about I must to think is: how to put vectors of magnetic field from "heater" in the same direction when we have upper sine part on output and the same with lower sin part. We must remember, we have two different frequencies (one high from heater, second one from our inverter on output).
This is only idea.
