0 Members and 137 Guests are viewing this topic.
energia9
Quote from: frankidel on August 01, 2012, 10:07:11 PM
OK government agent, enlight us, give us infos if you have any .................
many dont understand the reason why i said "im a government agent dont believe me"   many may think im trying to get this forum in some other direction when im just trying to help really.
you have two thick coils there.
both of them are primaries and located on a third coil
both primaries fire at the same time and are in phase,
both primaries operate on the same frequency
third coil is a carrier of high frequency and high voltage resulted from 2 primaries.
first primary s power draw is from initial power supply,
while coil primary two's energy supply come from an output coil located underneath (middle) the third coil.
you need to see wheter primary coil 1 and 2 are in right place..
if any is on the bad location,  one of the primary coils will cancel the other 1 and also "suck" the energy away from the third coil
one of the primary coil must be further away from the third coil because of this. (outwards)
you need to correct the time differences between firing of two primary,
you need a proper circuit for stabilizing voltages and time control  of second primary coil which is responsible for creating a higher magnetic field on the third coil.
there are no frequency mixing involved,  resonance frequency has to be obtained ,  but has to be kept on with other coils too.
! Static Energy dont get lost,  if not controlled it gets conserved on nearby objects or in earth. !
if controlled it can be used for useful purposes
your most important step is not some frequency find,  but timing of these two primaries ,  tuning them to fire at the exact time without affecting eachother .
forest
energia9
from some experience I can tell you are saying truth  8) if you people would listen to what Tariel said (in Russian language) you would immedately find that he said about electromagnet
what is this is a artificial created permanent magnet then interrupted
I wish I could have ten years (like Tariel had) to analyse this concept throughfully
Ganzha
Here is some hidden connection between Stevep and project of Victor from Ukraine//
When I had published a Viktor's concept at first time stivep keept a silence....
then someone successfuly repicate induction heater project//
/now Stivep is in "active mode" and pretens that he has a secret and he is ready to open  this to some right people (possible whom has good shape of sculp) or.... whatewer whom..
or this is just a paranoya?
;D 8)
FreeEnergyInfo
Quote from: FreeEnergyInfo on August 01, 2012, 07:14:40 AM
NIKO NIKO GRYNBOKS KAPANADZE ....
VIDEO ...
www.youtube.com/watch?v=9dK1z8YZAEs&feature=player_embedded
SCHEMATIC ....
ИндукÑ,ор он же резонаÑ,ор Ð"ерца выполняеÑ, защиÑ,ную Ñ,,ункцию оÑ, перенапряжения и Ñ,ока.
НасÑ,роен на часÑ,оÑ,у Ð'Ч резонанса последоваÑ,ельного LC конÑ,ура.
Принцип дейсÑ,вия основан на развороÑ,е полярносÑ,и=Ñ,,азы.
По Ñ,акому принципу рабоÑ,аеÑ, большое количесÑ,во извесÑ,ныÑ... усÑ,ройсÑ,в. (Изучаем по ссылке)
www.ruselt.ru/techinfo.php?id=5&ap=2&ap1=20
""""Ð' ряде исÑ,очников можно всÑ,реÑ,иÑ,ÑŒ Ñ,акже название «акÑ,ивный кондиционер гармоник, АКÐ"». Принцип дейсÑ,вия АФÐ" основан на анализе гармоник Ñ,ока нелинейной нагрузки и генерировании в распределиÑ,ельную сеÑ,ÑŒ Ñ,акиÑ... же гармоник Ñ,ока, но с проÑ,ивоположной Ñ,,азой""""
Если Ð'Ñ‹ внимаÑ,ельно смоÑ,рели Ñ,,ильм Турецкий Ð'арианÑ, с синими каÑ,ушками Ñ,о в соседней комнаÑ,е видели Ñ,акую КРМку. Но именно в гринбоксе Капанадзе на мой взгляд гениально решил вопрос сÑ,абилизации выÑ...одной мощносÑ,и усÑ,ановки независимо оÑ, поÑ,ребления нагрузки, применив для эÑ,ого просÑ,ейший широкополосный (поÑ,ому чÑ,о из Ñ,рубки) резонаÑ,ор Ð"ерца.
Ð"енерация мощносÑ,и в усÑ,ановки осущесÑ,вляеÑ,ся за счеÑ, возбуждения нечеÑ,ныÑ... гармоник.
Именно нечеÑ,ные гармоники вызываюÑ, повышение Ñ,ока и амплиÑ,уды напряжения в цепи низкой часÑ,оÑ,Ñ‹ 50 Ð"ерц. МощносÑ,ÑŒ как Ñ,аковую создаваÑ,ÑŒ не нужно за нас позабоÑ,илась маÑ,ушка природа подарив нам землю.
Именно она являясь огромным генераÑ,ором посÑ,оянного Ñ,ока будеÑ, вечно посÑ,авляÑ,ÑŒ элекÑ,ричесÑ,во.
Основная задача коÑ,орая сÑ,оиÑ, перед изобреÑ,аÑ,елями эÑ,о "забраÑ,ÑŒ" сгенериÑ,ÑŒ эÑ,у мощносÑ,ÑŒ пиÑ,аясь по одному проводу, с чем прекрасно справился баÑ,он Тариэль.
P.S.
balphom
am new in this forum but i have been a follower for almost one year now. i have done allot of experiments concerning the kapanadze thing. we need to ask our self a few questions and if we have the answers we already have the device. in the green box video there seems to be some arguments about counter in the 20th min, one of them say the counter will not sustain 5kw so they decide to increase load gradually. they load it with one bulb and the current in the meter 5amps agrees with one 1kw bulb, on adding the second one the meter reads 8 amps less 2 amps. but when they were using the tap it could hold 5kw because of the good grounding. so they decide to add the ground tap to the output of the load and it sustain 5kw again. this device only use one ground not two as many says there was a reason to add the second ground. so the question is what is counter, how do we create this counter, and how do we harvest it. remember one thing when trying to think about this they are measuring this counter from the cable from  ground.
