0 Members and 419 Guests are viewing this topic.
Zeitmaschine
Can the metal workers amongst us identify some of the tools and/or materials seen in the stills from the 2004 video?
Can tell what tool I don't see: a soldering iron. Could be the only means he had was a blowtorch. ;D
It looks like TK was doing copper and brass works. This could almost lead to the idea that the tube the coil is wound on could be made of brass. But then, if this is ever relevant, where is the metal tube in the Turkey 100KW setup? And where is it in the patent specifications?
And why is it that Leedskalnin specifies brass or aluminum for the coils forms? Why not simply cardboard?
Anyway try a coil on brass/copper/aluminum tube. The outcome cannot be less than nothing.
stivep
Quote from: Zeitmaschine on August 02, 2012, 09:00:12 PM
On the photographs above there is solder that is not melting.
why than  TK used flat copper strip? ??? ??? ???
due to temperature..........the larger the area of contact the harder is to solder it  so higher temperature is needed to un-solder it as well.
what do you think about it?
The slot on left photograph is to keep the distance of inner winding to copper thick coil. yes? no?
next thing:
switch is screwed with  nut  to large copper plate,( well nut is not there)  than the plate ( plaster of copper) is soldered to brass upper circle. Why he needed dual thickness of metal  there?
Because of temperature dissipation I assume?
ups: I  just found something:The switch is not flip switch.  It looks like regular Russian flip but is in  vertical coaxial position This switch is modified switch. Or already non working as a switch.
Why?
It looks like his device was made  only to work for  quite limited  amount of time and he experienced thermal dissipation problem......I assume.
And switch by itself is made inside from Bakelite. that material can hold quite high temperature bit not as  high as temperature of melted solder.
Question does anyone  noticed  that TK was using that switch at all?
or was that lisle handle from the switch used as the leverage, handle to activate reaction inside? sort of the steerer ,
rudder, paddle.
Wesley
Tito L. Oracion
WHY DOES THE SUN IS FULL OF ENERGY  8)
SIMPLY BECAUSE ITS HOT?  :o
WHY LIGHTNING STRIKES?  8)
SIMPLY BECAUSE OF FRICTION, AND WHEN THERE IS FRICTION, ENERGY IS FORMED ALSO  ;)
IN THERMOCOUPLE, CAN YOU FIGURE OUT HOW MUCH CURRENT IT GIVES?
VERY LOW VOLTAGE BUT LOTS OF CURRENT.
IN FUSE WE USE THE SAME CAPACITY IN AMPERE AND NOT MINDING THE VOLTAGE  ???
???   ???   ???   ???   ???   ???   :o
;D
[size=78%]
[/size]
[size=78%]
[/size]
[size=78%]
[/size]
[size=78%] [/size]
a.king21
T-1000
People may not comment.... doesn't mean we are not thinking about it. I don't comment on induction heater, but it goes into my "mental suspense account". As we are FE  researchers we do take it in. Keep posting. No comment usually means "good idea, wonder if I can devise an experiment".
Tito L. Oracion
HAPPY REALLY NEW YEAR EVERYONE  :-*   ;D
metal diode metal diode   ???   ::)  hmmmmmmmmmmm
why not?  ;D
