0 Members and 44 Guests are viewing this topic.
grizli
Quote from: Omnibus on April 02, 2010, 03:02:06 PM
Thanks @DeadZone for the transcript.
The main points in it are:
Heating system used as ground.
Shows the output transformer.
Output transformer is made on ferromagnetic core unlike the misconception people have that it should be an oscillatory circuit.
For lack of battery he uses a 12V power supply.
Further, the system charges a 4700uF cap and is used to power the system.
Turns the system on.
Fan goes off as well as two power transistors and our favorable arc.
A 150W lamp is also being powered.
150W is the maximum he could get. There’ll be more in the future.
Now the external power source is disconnected and the cap is discharged by shorting the leads.
Lamp, arc keep working.
Transistor is used to generate, that is, feeds the high voltage transformer and that transformer generates the arc, that is, not arc but high voltage.
The arc isn’t powerful and need not be.
It stimulates the process determined in the ferromagnetic core.
Further, there’s a 20W transformer fed by the output coil which feeds the 150W lamp.
To stop the device the cap has to be discharged.
Once cap is discharged the device can’t be turned on.
To turn it on external power source (12V, 1A) has to be used again.
At the end, he repeats that process of turning the device on once again.
Now what remains is to have our good forum members @bartoulogos, @madsatbg, @xenomorphlabs, @grizly etc. reproduce this simple schematic
This schematics is NOt simple because it is unknown hehe :D
QuoteFurther, there’s a 20W transformer fed by the output coil which feeds the 150W lamp.
20W transformer feeds 150W lamp or output coil feeds 20W lamp and transformer together
Omnibus
He says the 150W lamp is being fed. I agree not everything is clear. You can understand what he says but what he says is somewhat loose talk.
See this:
QuoteÐ"алее все подключено. СÑ,оиÑ, Ñ,рансÑ,,ормаÑ,ор на 20 ваÑ, снизу.
КоÑ,орый запиÑ,ан оÑ, Ñ,ой выÑ...одной каÑ,ушки.
Ð'оÑ, эÑ,о Ñ,рансÑ,,ормаÑ,ора одного и оÑ, него же запиÑ,ана лампа.
ТоесÑ,ÑŒ в данный моменÑ, видим мощносÑ,ÑŒ 150 ваÑ,.
The output coil feeds the 20W transformer and that transformer feeds the 150W lamp.
In these controversial matters everything has to be clearly enunciated and it isn't, unfortunately. It's not only in this case, everywhere in the OU research everything is mostly guesswork. Pretty sad state of affairs.
hartiberlin
Well, it is really a different circuit in the video than the one
posted in my last message.
I just watched it now several times again and you can already see,
that one transistor on the heat sink is directly connected to a coil
on the blue aircore ? or ferrite ? transformer.
Also the output bulb is conected differently as the ground wire is connected
directly to one pole of the lamp, which he is also touching.
In the upper circuit diagramm the ground still goes through another coil first,
so it is really different.
Well, I hope that this youtube user SR193 comes forward with a real circuit
diagramm or at least explains what is really needed for this effect to work..
Many thanks.
Regards, Stefan.
xenomorphlabs
QuoteWell, it could be that the 2 transistors and this
switch at the back are only the circuit to
switch between 4700 uF supply and
selfrunning supply and that the posted simpler
circuit diagramm is just the basic selfrunning
circuit ?
Hmm, a simple switch that needs to be cooled by large heatsinks and a cooler?
The cooler implies that the transistors are constantly running and
he sais in the video : the transistors serve for the generation of high voltage.
The fact that it is 2 and not 1 transistor can indicate that this
is for creating a non-pulsed, sinusoid HV.
Stefan had a good idea. To look at the video closely and reconstruct
the possible schematic, the wires are a bit messy, but it should be possible to get a majority of the visible connections.
Omnibus
Stefan, he emphasizes the ferromagnetic core. That seems to be his main point, everything else being trivial. Otherwise, you may be right about the lack of transistors in your earlier comment. Indeed, it would be good if he would come here and explain that more clearly. Reminds me of earlier cases where claimants would halfheartedly show something only to disappear suddenly, let alone those who were showing outright fraud.
