0 Members and 27 Guests are viewing this topic.
Zeitmaschine
Just thinking: If a step-up transformer is constructed in unilateral induction manner and the secondary is properly back looped to the primary, what could happen? 220V in = 440V out = 440V in = 880V out an so on... ? Until the voltage is high enough to fire a spark gap after a few cycles? If this works at all then this should work even with 220V in > 221V out.
»Hence it is clear that very different picture of the magnetic field is a two-layer coil, if after the end of the first layer of winding the wire is bent 180 degrees back and the second layer is wound in the opposite direction.«
METHOD OF IMPLEMENTATION OF UNILATERAL INDUCTION
a.king21
dole
Quote from: a.king21 on August 08, 2012, 04:32:31 PM
I enclose another photo. The output coil pack is clearly visible. Remember it has nothing to do with the patent. The patented device is hidden inside a black box.
black box: it must be capacitors and if it should be simple he is charging them and discharging through load back to source in closed loop gaining charge as shown in his patent.  TK reference to Tesla: Tesla believed that capacitors is source of unlimited energy, he did not believe, he knew. So it myth remain only one simple question, how exactly TK "switching" them.
d.
a.king21
there is another fact
In presentation in island
TK left one of his folks in the hotel in the steady ground.
He has chosen the hotel
Near the hotel there was High to low  transformer.
The hotel was about to lose power.
Wesley
Why have you waited a year to tell us this fact?
cheappower2012
a.king 21
The green transformer, any information on that part,very strange part,it maybe that the spark,and the coil maybe a fake out.
If you pass the 220 vac thru the coil that's being pulsed by the large coil,you get pulses
that interfer with taking an ac voltage measurement,I posted an experiment showing this,
this interference is shown in the green box video.
