0 Members and 27 Guests are viewing this topic.
a.king21
Quote from: Zeitmaschine on August 08, 2012, 07:45:37 PM
Just thinking: If a step-up transformer is constructed in unilateral induction manner and the secondary is properly back looped to the primary, what could happen? 220V in = 440V out = 440V in = 880V out an so on... ? Until the voltage is high enough to fire a spark gap after a few cycles? If this works at all then this should work even with 220V in > 221V out.
»Hence it is clear that very different picture of the magnetic field is a two-layer coil, if after the end of the first layer of winding the wire is bent 180 degrees back and the second layer is wound in the opposite direction.«
METHOD OF IMPLEMENTATION OF UNILATERAL INDUCTION
I agree. Lets build it  and see.
frankidel
Quote from: dole on August 08, 2012, 08:15:19 PM
black box: it must be capacitors and if it should be simple he is charging them and discharging throughout load back to source in closed loop gaining charge as shown in his patent.  TK reference to Tesla: Tesla believed that capacitors is source of unlimited energy, he did not believe, he knew. So it myth remain only one simple question, how exactly TK "switching" them.
d.
http://www.youtube.com/watch?v=jim3Q_k-K9Q  background ambiant energy, maybe it could help you.
a.king21
Quote from: frankidel on August 08, 2012, 08:40:49 PM
It's hard to keep this forum on track.  Kapanadze has a patent which clearly shows 2 coils interacting to produce ou.
They are not the visible coils in the builds, but are hidden inside closed containers. Stick to the patent for now. Don Smith is suspect at best. At least with Kapanadze we have a working machine. The only question is, "Does the energy come from the ambient background/aether/zero point or whatever you want to call it, or is he somehow abstracting electricity from the grid - either indirectly, or directly?"
Let's keep on the rails.
Free.Energy
In the green box video, the clamp meter is set to the second position (clockwise) when measuring the thick cable.  The same meter is then switched to the first position (clockwise) when measuring the white wires from the inverter.
