0 Members and 61 Guests are viewing this topic.
27Bubba
Quote from: forest on August 09, 2012, 03:57:51 AM
C'mon 27Bubba -  why you think there are two ground connections ?
Because they are there..
Did you watched green box video carefully ? There is also a video somewhere with english subtitles. I can't find second ground there  - just in first part a car radiator was buried in soil with cable attached, then device was gronded to water faucet.
Correct the radiator(1) and the faucet(2)... Those are the ground connections I was referring to.
Best..
27Bubba
@forest
I guess I should be more clear. The point I was making even thou TK devices evolved, internally all share the same concept covered inside boxes..
Question I have, how many wires was going in and out of the boxes? I believe we should try to decipher the box..
captainkt
@a.king21, just a note you talk about the Neutral connected to Earth as a danger? Almost half of UK grid is PME with neutral earthed.The return wire to gen stations is via Earth grounding. I can run my house with just a live 240 volts to Earth with no power loss and the meter load not changing. This does not alter the steel safety cage of things like washing machines which also go to earth. If I hold a live wire and touch Earth I will get a shock just as if touching Neutral.The safety issue is easily fixed as with any power source.
Keith
27Bubba
Quote from: captainkt on August 09, 2012, 08:14:59 AM
Keith
The same applies in the US. The common (white) wire and the ground (green) wire share the same terminal connections at the fuse box. The power (black) wire connected to fuse and it use separate bar terminal.
anandml
You can also use the earth ground to gain more electrical energy into your capacitor by using one leg (the Negative) from the  Inverter output not AC supply!
        Capacitors store and discharge free energy! Radiant energy is stored in between the capacitors plates and the electrons rest on the metal plates themselves. Radiant energy is also created at discharge time. I think bifilar coil set up and spark gap is mainly used to maintain cap charging and discharging period of time (because capacitor will take some more seconds to store electric charge). Using this technique we can able to convert Low voltage  DC supply with less ampere into low voltage with more ampere. Amperage rate depend upon capacitor specification. I think TK used two inverter circuits especially two step-up transformers in every demonstration video...
regards
ANAND.M.L
