0 Members and 37 Guests are viewing this topic.
sparks
   Does anybody recognise the tesla transformer?  What is different in a Tesla transformer compared to an  ac control transformer for say ringing a doorbell.  Why can a Tesla transformer produce thousand fold voltage increases compared to an ac control transformer.  Why would anybody run a wire to ground up the inside of a transformer that is ringing?
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
sparks
Quote from: anandml on August 09, 2012, 09:32:58 AM
You can also use the earth ground to gain more electrical energy into your capacitor by using one leg (the Negative) from the  Inverter output not AC supply!
      Capacitors store and discharge free energy! Radiant energy is stored in between the capacitors plates and the electrons rest on the metal plates themselves. Radiant energy is also created at discharge time. I think bifilar coil set up and spark gap is mainly used to maintain cap charging and discharging period of time (because capacitor will take some more seconds to store electric charge). Using this technique we can able to convert Low voltage  DC supply with less ampere into low voltage with more ampere. Amperage rate depend upon capacitor specification. I think TK used two inverter circuits especially two step-up transformers in every demonstration video...
regards
ANAND.M.L
The big ball we are riding on is charged negative compared to space.  Such other objects as the moon mars jupiter sun etc also have electric fields terminating on them.   Pressure-gravity-voltage all about the same thing.  The ones that spin of course have magnetic fields associated with them otherwise they are just dust in the wind.  If you put a plate capacitor on a bearing and alternately charge and discharge said capacitor.  You can get the capacitor to start spinning as one plate gets "lighter" than the other.  Of course the lighter plate will be charged positive (like space) and the other negative (like Earth) http://www.einsteingravity.com/
Think Legacy
Spread the Love
a.king21
Re neutral grounding: I take the comments on board. However, for safety reasons we do not expose the wire in that way.
I guess TK does it that way to show that the device has no hidden direct power source.
TK has said that the ground wire can be replaced with a circuit.
- classic Tesla stuff - ie the negative terminal of a car battery.
So my take on it is that it is a standing wave.
A standing wave gives automatic resonance. In TK's patent the standing wave is attached to both
coils. So I believe I have solved the mystery of how he has solved the resonance problem between the two coils.
If anyone replicates the TK device then pm me.
In any case it is one more reason to recognise that TK has something real.
Re starting the device and switching it off - I am awaiting confirmation.
JJUK
@ a.king21 and mike140366
I'm assuming that should you manage to work out how the device operates (with or without help from the members of this forum), it is your intention to pursue your previously described plan to commercialise the technology for general usage. Would you continue to open source your research up to and beyond this point? I personally have no problem with investors reaping reward from their investments and inventors gaining from their inventions (and at this point I suspect the $20k directly invested is more than anyone else who has published on this forum). However, I believe that it would be helpful for everyone to understand your approach up front.
x_name-41
Hi a.king21, I was interested in two output wires on the inside of the tube pass all or only one them?
