0 Members and 44 Guests are viewing this topic.
captainkt
Approaching 850 posts but I feel the last few the most usefull. Thanks to all concerned, I will now alter my direction slightly, 100% work with earth grounding (1) only, also use inverter. When Tarial self runs the 2004 gen he includes the blue inverter in circuit and does not feed back direct, same in green box vid inverter is kept in loop. Later gens probably have inverter hidden in circuit. Does anyone know if this model (blue box) is sinewave or modified sinewave. This could be important as when I try to use modified sinewave to run Induction hob I get no output to pick up coil at all, tried this on three hobs plug to mains and hobs work. Also came to same conclusion as many others that the visible coils are just output trans and not anything special.
Keith
a.king21
The device was started by the application of a 9 volt pp3 type battery. The normal way TK starts his devices.
The device was stopped by a button on the outside of the box.
It ran for maybe 1 to 2 seconds after the button was pressed and then stopped.
In other words, the spark gap continued firing for a maximum of between 1 and and 2 seconds after switch off and then stopped.
captainkt
Zeitmaschine
Quote from: a.king21 on August 08, 2012, 09:08:58 PM
It's hard to keep this forum on track.  Kapanadze has a patent which clearly shows 2 coils interacting to produce ou.
They are not the visible coils in the builds, but are hidden inside closed containers.
If so, that means nothing less than that all these photos of aquarium II are worthless, because the real device is hidden in black boxes. >:(
But it does not mean that the OU theory of »Unilateral Induction« is invalid.
a.king21
Quote from: Zeitmaschine on August 09, 2012, 04:45:29 PM
Yes and no. What it means is that we can stop wasting our time with spark gaps, Tesla coils and Kacher devices. That's not the principle.
But what have we learnt:
1 The actual ou device is LIGHT.
2 The actual ou device is SMALL.
3 The actual ou device generates no heat.
4 The actual ou device is simple.
5 The actual ou device comprises 2 coils and some extra components.
Don't you think that is a breakthrough?
