0 Members and 71 Guests are viewing this topic.
a.king21
Quote from: Cap-Z-ro on August 09, 2012, 06:55:25 PM
I said this before and I believe it bears repeating...this device may operate on the same principle as Nathan Stubblefield's coil.
Regards...
Maybe.. also tpu and meg. But one thing is certain. We have 2 patents to analyse. Only 2 coils to configure.
The rest is conventional electronics. Can you post any Stubblefield links you have. It will be worth a look in any case. The minute we find something which resembles the panel beating equipment and stuff in the 2004 video - we will have it.
Cap-Z-ro
" Can you post any Stubblefield links you have. It will be worth a look in any case. "
There is a rather extensive thread on here started by Pirate (Bill).
There were many replications, links and theory's put forward by a number of members...that would be your best resource.
Hope that helps some.
Regards...
x_name-41
cheappower2012
 x_name-41
,you are right in a way however the path is thru the transformer,to me you
apply a voltage with a given amount of current
there is an amplification of energy no voltage increase.The answer has to be
simple, also has to be something TK fooled with.
With these guys(TK,SM) lying is a way of life.The turkey device was 3 phase,if they
didn't know this was the source
they would miss it.Also to achieve a current amplification requires a source of
energy,this same energy powers the tpu,energy in my view is applied to other
electrons to increase energy flow,in an ac system there is no current flow only
a transfer of energy.In the tpu there is an
increase in current flow
since the output is a series of fast dc pulses 5,000 to 6,000 a second,each pulses
current is increased.The difference between the tpu and Tk device is the energy amplification
is in short times in the tpu and dc,in the tk device,its continuous thru out the cycle
so the power is going to be much greater,this is needed to power cars,heavy industries
and reduce oil use to nearly nothing. Conventional thinking  will
not work on either the tpu
or this device,your going have to think way outside the box.
So far only the tpu and the tk device could be real world devices in my view, I have looked at a lot of other devices,there fake,or inputs and outputs were not calculated correctly.Any device
that can generate energy in this matter is not going to operate under conventional physics laws,with the exception of conservation of energy and matter.You can not introduce a device like either the tpu or tk's device in any form with out causing a global crash,however when the dust clears it will be a much better world.
It is not  a Tesla invention.
Zeitmaschine
Quote from: a.king21 on August 09, 2012, 09:27:02 PM
This leads to the simple but profound question: How had TK recognized that there was OU in his 2004 device in the first place? I don't think he had 5 pieces of 1KW lamps hooked up to the device from the beginning. What was TK trying to do prior to his discovery of OU? Especially if one considers his inappropriate workshop equipment in respect of electronics.
I would appreciate any ideas.
