0 Members and 370 Guests are viewing this topic.
Hoppy
Whilst its quite possible that the device was being mains fed through the earth cable, we must remember from previous sagas like Romero's self-running motor, that video's are proof of nothing. Over speculating on what may well be a tank full of eye candy is rather pointless.
Hoppy
Jack Noskills
Quote from: Zeitmaschine on August 10, 2012, 07:30:27 AM
Then there is a problem we have: If the big prominent coil in 2004 video belongs to smoke and mirrors (because it's visible) then there is not much room left in the 2004 tin can for any real coil which can produce a power output of 5KW.
And who says that the whole convoluted patent with its two prominent coils is not smoke and mirrors also? Maybe no coil at all is needed in TK device?
Then again I can confirm due to my own experiments that the Unilateral Induction is working as described (see drawing below), but the question remains how to connect the coils (in resonance) to get OU.
Maybe I was not clear enough but,
I have already solved this, coils connected so that output does not affect input and output power exceeds input power.
As long as you have primary that uses magnetic induction on secondary there is always magnetic induction back to source. Simplest solution is to separate the primary outside secondaries, two secondaries then feed each other. Do it my way, it is Don Smith for dummies sort of thing. Meaning power output is at Don Smith level, but making of the device is childs play. Just one rule, high impedance coil connected as shown in the thread. High impedance you then achieve with: frequency, permeability, number of turns or tuned cap.
Just one builder is needed to try it out, who's got the brass balls to do it ?
frantz
Quote from: x_name-41 on August 09, 2012, 10:38:22 PM
Maybe like this, current amplified from a top coils?
Hi x_name-41,
coil on your picture looks like big choke.
Maybe this is only filter of output signal?
And the main part of generator is hide inside black box.....
leo48
QuoteJust one builder is needed to try it out, who's got the brass balls to do it ?
Ok this is the coil pattern to reply # 12744 but does not work  :'(
Give me a schema and see how ... ;D
Leo48
Every problem has always at least two solutions simply find
The strength of the strong is the ability to navigate struggles with eye serene
frantz
