0 Members and 98 Guests are viewing this topic.
hartiberlin
Quote from: Goat on April 02, 2010, 06:23:15 PM
@  hartiberlin
The circuit you posted a page back at http://www.overunity.com/index.php?topic=7679.msg235962#msg235962
"was the obvious wrong schematic posted"
Regards,
Paul
Hi Paul,
I had only scaled it down and posted it here directly as an attachment.
The other user said:
"onem an on next energy posted this"
But at what exact link was it posted ?
Did he tell anything still about it ?
Omnibus
That guy plays extremely offended and uses that as an excuse to be vague. We've seen that before (@alsetalokin comes to mind). No new registrations are accepted in his forum and I wonder if @grizly can log on. I think he was registered there.
hartiberlin
Quote from: Goat on April 02, 2010, 06:09:04 PM
Hi All
I just looked at the video again in high definition and it's clear in the audio that the hum is always present even after disconnecting the power supply so based on the circuit diagram and the video it seems like either the circuit is being fed via 50 Hz power or somehow it's self running using all the components to self generate 50 Hz power...
No,
I have the higher res MP4 version with good sound and
the circuit only makes noise, when the light bulb is on.
If the light bulb is out also there is no hum or noise.
Maybe you heard the hum of the small
12 or 15 ? Volts power supply he used to start it , cause this
also has of course a transformer in it.
But when that is turned off, there is only noise from
his main circuit, when the light bulb is on and thus
his circuit is running.
Goat
Quote from: hartiberlin on April 02, 2010, 06:30:47 PM
Hi Paul,
@ hartiberlin
The same schematic as you posted was from this post...I personally don't see any resemblance to the video because of the lack of components in the schematic....
http://www.overunity.com/index.php?topic=7679.msg235940#msg235940
Regards,
Paul
xenomorphlabs
It is self-running at 50 Hz, that´s the whole point of it.
The 4600 uF input cap is being charged probably through a rectifier
off a little pickup coil or a voltage divider off the transformer ends(just as described in kapanadze´s patents)
QuoteUnless this unit is independently tested it looks a little too Mylow in my books
Comments like that made him close his site ...
You may not have read about his motives earlier in this thread, so your prejudices are based upon lack of information.
