0 Members and 248 Guests are viewing this topic.
a.king21
Quote from: Free.Energy on August 11, 2012, 01:31:03 PM
Why is the large circuit board in the clear box painted black?  Looks like it came from industrial equipment.  One side if this board has outlets for electric plugs like it may be an inverter.  What if the black box has a battery to start the energy?
Kapanadze may not be able to make an H-bridge, but he may be able to find a motor driver that has H-bridge.   Sure Kapanadze can build a multivibrator and the green box device had two transistors on top.
He could well have a battery to drive output transistors. We have discussed that. The battery would then be recharged by the system. It's not the principle though. We are looking at finding the principle.
We have come to two conclusions:
Either he is generating electricity via resonance
or: He is receiving electricity wirelessly using longtitudonal waves.
Even if it's the latter, it is still useful technology because we can get rid of wires in the home and power electric cars.
So either way there is a business.
So come on guys: replicate and let's do a deal.
Free.Energy
Quote from: a.king21 on August 11, 2012, 02:24:05 PM
Tesla held an interview when he was old and he stated that resonance was just a means to increase a small signal and that you can do better with an ordinary transformer.  There is no extra energy in resonance.  Tesla shows the use of an ordinary transformer in his colorado notes as another way.
I think Kapanadze is creating the scalar wave around the inner winding of the large coil and collecting the converted energy in the windings on the outside.  The energy flows through the load to ground.  If this is so, we only find the pulse rate that works.  I have pulse driver and wire for coils but the rate is too fast with 1MHz and good rate may be in kHz range.  I can modify to go slower with time.  At 1MHZ there is only a strong electric field and sparks if you touch objects.
The rate of the spark gap does change when the load is turned off in the clear box video. The english speaking man says this.  This gap is related to the load by some method.
frantz
Quote from: Free.Energy on August 11, 2012, 02:47:10 PM
Hi I've short question:
How do you think, TK knows what is a scalar wave?
verpies
Quote from: cheappower2012 on August 11, 2012, 09:13:10 AM
This is size to handle a 2kW load,US
Weight 55.00 lbs. (24.94 kg)
LxWxH 9.00 x 6.00 x 6.75 in.
(22.86 x 15.24 x 17.15 cm)
For 60Hz AC and a laminated silicon steel core that seems about right.
For 5kHz AC the transformer could be much smaller.
Nanocrystalline core would allow for even smaller unit.
a.king21
Quote from: verpies on August 11, 2012, 03:22:04 PM
We're pretty sure he uses capacitors for output. In other words he dumps his energy into output capacitors and powers the
load from these. When he switched the device off the spark gap continued firing, but slowing for maybe 2 seconds. This would indicate capacitors.
