0 Members and 520 Guests are viewing this topic.
x_name41
Hey to all, maybe if you are using software from this website will be clarified some details? http://www.cse.cuhk.edu.hk/~leojia/projects/robust_deblur/ , or comming soon new deblur filter plugin from adobe photoshop cs6 ;)
Free.Energy
I sharpened and modified several frames and there is a lot of information maybe not enough.  More than later videos.
If TK had to use a spark gap to limit the voltage collecting then there is a way to collect more current and no spark gap.
anandml
Quote from: Free.Energy on August 11, 2012, 06:11:31 PM
We see the familiar roll for paper with the TK coil.  Notice the spark gap connected to the secondary and take a few seconds to start.  I say it must charge the space around the coil before the spark gap works.  When TK  tuns off the blue inverter box, the light go out a few seconds later.  Again, I say the space around the coil is the energy stored and this runs out through the lights.
I think the coil present in a PVC pipe will act as parasitic capacitance..... For example, an inductor often acts as though it includes a parallel capacitor, because of its closely spaced windings. When a potential difference exists across the coil, wires lying adjacent to each other at different potentials are affected by each other's electric field. They act like the plates of a capacitor, and store charge. Any change in the voltage across the coil requires extra current to charge and discharge these small 'capacitors'. When the voltage changes only slowly, as in low-frequency circuits, the extra current is usually negligible, but when the voltage changes quickly, as in high-frequency circuits, the extra current is larger and can be significant. At low frequencies parasitic capacitance can usually be ignored, but in high frequency circuits it can be a major problem. In amplifier circuits with extended frequency response, parasitic capacitance between the output and the input can act as a feedback path, causing the circuit to oscillate at high frequency.
anandml
Quote from: x_name41 on August 11, 2012, 10:19:10 PM
Thanks a lot.... Website link for blur removal from youtube video trick  http://www.5min.com/Video/How-to-Remove-Fullscreen-Blur-from-YouTube-Videos-11657291. if u know any other software related to  blur removal from video pls post a link
Muromets
