0 Members and 114 Guests are viewing this topic.
frantz
Quote from: Muromets on August 12, 2012, 02:35:47 AMIt's a voltage multiplier UN9/27 http://high2014.ru/energy/hv/7/1/7.jpg
If this is a multiplier, where is flyback?
And in final TK must use DC HV if using multiplier...???
What is charged by this circuit? HV cap...? What for?
General question is: Is he using some big caps or not?
If yes, this caps can't to be HV....
forest
frantz
Quote from: forest on August 12, 2012, 04:54:35 AM
I already posted that....  >:(
Are you sure? Under the scrap? with "long" distance to multiplier? for misdirection?
Maybe you have right, because some wires from silver plate with transistor going there...
I think this relatively small transistor can powering this flyback.
But what about caps? Are they using or not? I think generating large current without cap is difficult.
forest
Quote from: frantz on August 12, 2012, 05:03:42 AM
Well, during years I collected a few (not so many unfortunately) various flybacks and one of them was from old Sony TV afaik with separated voltage multiplier connected via 20-30 cm HV cable to flyback , that one completly wrap up in resin-plastic box. If this is the case you cannot (it would be stupid) cut the connection from flyback to HV voltage multiplier.
bbem
At the http://www.energeticforum.com/renewable-energy/4864-donald-smith-devices-too-good-true-237.html#post205432 forum I read this.
Does this make sense?
Quote from: xilo;205432a gravity field of a coil pulsed with dc is always perpendicular to the magnetic field.
normally when we use alternating pulses this field gets cancelled.
a ferrite core coiled with copper wire  in shape of a toroid produces anti gravity field or artificial gravity.
when two gravity field interact perpendicular to each other produces electric energy.
a solenoid placed horozontally in front of a toroid wound with coil. this toroid coil is pulsed with hv dc produces bursts of strong gravity force out of the orifice of the toroid. when this gravity force interacts with solenoid coil which is experiencing natural gravity force give rise to an electric vector which produces current in solenoid coil.
this is the basis of kapanadze electric generator and electric motor.
its the gravity he uses which is always freely falling and is a monopole force acting vertically downwards.
this text is important for free energy followers and seekers.
XILO
Regards,
Bert
