0 Members and 561 Guests are viewing this topic.
Hoppy
Quote from: a.king21 on August 12, 2012, 08:05:30 AM
Sorry, no. At the time we thought the negotiations were going well and this was just an initial demonstration. However the heater was handled and behaved normally - no shocks or funny sensations or noises. Mike had one of those heaters  when he was younger and said everything about it's performance was just as he remembered an ordinary heater plugged into the mains would behave.
This is perhaps the most important area to study and measure carefully. Not just device output measurements but a good look at the fire itself including 'cold' measurements of the fire elements - resistance & inductance. Maybe its not too late to do this??
Hoppy
27Bubba
@wesley
"The  cement was done  fresh with one screw to it?
please ask yourself questions I  have  mentioned in video and look at  pictures comparison"
I was wondering the same thing about the ground screw...  This concrete area with screw looks sort of out of place, and pay an attention to this man showing the ground screw how cautionary he swiped at the screw initially as he was expecting a electrical shock ;) ;).
x_name41
Did you know if not mistaken  I think that output windings of green transformer are low voltage and connected in parallel to produce a strong current and one wire connected to ground and the other wire connected to a blue non inductive coil, a small toroidal coil behind the blue should also participate in the process.
frantz
Quote from: x_name41 on August 12, 2012, 12:41:59 PMDid you know if not mistaken  I think that output windings of green transformer are low voltage and connected in parallel to produce a strong current and one wire connected to ground and the other wire connected to a blue non inductive coil, a small toroidal coil behind the blue should also participate in the process.
XName
As somebody wrote previously, this transfotmer can operate on 500W totally.
Question is where is rest of the power...:-(
