0 Members and 84 Guests are viewing this topic.
Free.Energy
Quote from: frantz on August 12, 2012, 03:46:53 PM
Free.energy
where do you have ground cable in this presentation... (not at all ;-) )
http://www.youtube.com/watch?v=lFiaBKW50yA&feature=player_embedded
We see wires all around this device.  We see white wires, black and red.
How are you sure that one is not to ground?
frantz
Quote from: Free.Energy on August 12, 2012, 04:31:12 PM
I'm sorry Free.Energy I was not precise
you wrote:
"See in all TK coils that the cable to ground is inside the coil.  Why is this?"
Tell me where do you see cable inside this coil?
Free.Energy
Quote from: frantz on August 12, 2012, 04:39:13 PM
It is very hard to see in this video with light so low.
Zeitmaschine
Quote from: Free.Energy on August 12, 2012, 03:23:33 PM
An alternate opinion:
2004 video was early prototype and nothing is hidden.
There is no means for overunity in an ordinary transformer.
There is no proof of that. Maybe it depends on the interpretation of the term »ordinary transformer«. If connected the »wrong« way the transformer isn't ordinary any longer.
TK method for driving TK coil is secret.  If you find translation of green box video in pdf from years ago TK says resonator is in the box and is secret.  TK also says he found way for primary to always resonate with secondary and he names this autoresonance.
But what is TK referring to? If the resonator is in the box (as he says) then he could refer to the primary and the secondary of an »ordinary transformer« that is secretly hidden in the green box - not to the primary and secondary of the visible coil.
The measurements are not successful since current is longitudinal else power flow to earth will not work.  Clamp meter does not measure longitudinal current with electric field parallel with wire.  This is where the answer will find.
This sounds like someone has successfully replicated the TK device, otherwise how can one be sure? I haven't managed yet to get 23 amps power flow to earth, hence I can't say what kind of current a clamp meter needs in order to measure it correctly.
The ether cares because electric field modifies ether but only with rapid change.  The repetition rate is what TK confuses with resonance.
Then at which frequency starts the modification of the ether and why at this frequency? Does a permanent magnet modify the ether?
Can't see this in 100KW presentation with head-high coils.
frantz
Quote from: Zeitmaschine on August 12, 2012, 05:32:03 PM
Only one I would like to say you Zeitmaschine: Respect for you :)
