0 Members and 104 Guests are viewing this topic.
frankidel
Quote from: Zeitmaschine on August 12, 2012, 05:32:03 PM
There is no proof of that. Maybe it depends on the interpretation of the term »ordinary transformer«. If connected the »wrong« way the transformer isn't ordinary any longer.
But what is TK referring to? If the resonator is in the box (as he says) then he could refer to the primary and the secondary of an »ordinary transformer« that is secretly hidden in the green box - not to the primary and secondary of the visible coil.
This sounds like someone has successfully replicated the TK device, otherwise how can one be sure? I haven't managed yet to get 23 amps power flow to earth, hence I can't say what kind of current a clamp meter needs in order to measure it correctly.
Then at which frequency starts the modification of the ether and why at this frequency? Does a permanent magnet modify the ether?
Can't see this in 100KW presentation with head-high coils.
Hi, maybe, if it is wired like additive or substractive way, just a thought.
a.king21
Quote from: ramset on August 12, 2012, 06:35:36 PM
dillbarre
a.king21 Where is your replication?
Why do you request people to PM you and not post their findings here in the open forum?
End quote.
yes this is an odd request for an OPEN SOURCE forum??
""Factories"" 10 KW deals gone bad!
whats up with that??
Thx
Chet
Read my previous posts.
a.king21
Quote from: frantz on August 12, 2012, 06:37:06 PM
and why are you so sure that it is ferroresonance?
Do you have some top secret info only FYI?
may be you are a novice entrepreneur and needs some bacground... ;-)
Thank you for the insult.
Free.Energy
Transformer theory is well explored well understood.  There is not magic in a transformer because there is no magic in an electromagnetic field.
Clamp meter have a frequency range that they operate in and the readings are erroneous outside this frequency range.  Many handheld clamp meters operate in a 400Hz frequency range and will not measure current of several kHz correctly.  Some clamp meters can work to 1mHz.
It is not the frequency that changes the ether it is the sudden change in voltage and high voltage is required.  The sudden change implies a high frequency but this does not mean the repetition rate is high and I doubt that TK is pulsing at mHz rates, but I bet he is pulsing and pulsing with a fast change.
In the 100kw demo I was told that he did not use the ground and that is was not required for this method.  I have not confirmed this and like I said, if there is no ground or another reference, then he must be using and inductive method in which the polarity is determined by the direction just like moving a magnet.
Koen van Vlaenderen has a theory.  This is not complete but looks good and explains many things I have seen or read about and not understood.  I understand much better now.
Here are some links to Koen's site:  view with firefox browser is best
http://members.tele2.nl/kovavla/device.html
http://members.tele2.nl/kovavla/theory.html
http://members.tele2.nl/kovavla/hoaxes.html
http://members.tele2.nl/kovavla/experiments.html
The page about hoaxes is very good and exposes Bearden, Bedini, Tewari, and others as the frauds they are.
a.king21
dillbarre
End quote.
Thx
Chet
Inventors need a reward for their efforts. Once rewards are negotiated, we open source. That's the deal. Otherwise people not contributing to this forum who can only offer insults get a free lunch.
