0 Members and 153 Guests are viewing this topic.
ramset
Wesley
You are a Warrior ....sometimes there is a Sixth sense about "the way things are".
We need more "Warriors"
Like this one "Sitting Bull"
""For us, warriors are not what you think of as warriors.  The warrior is not someone who fights because no one has the right to take another life.  The warrior, for us, is one who sacrifices himself for the good of others.  His task is to take care of the elderly, the defenseless, those who can not provide for themselves, and above all, the children, the future of humanity.”
Sitting Bull""
Warrior,  Chief of Teton Dakotas (Hunkpapa Lakotas) and Holy Man
1831 â€" 1890
Not for Money ..as you say "How much is enough"??
Let us set an example for the next generation .
And we will!!
Thx
Chet
Thanks Grandma
Hoppy
Quote from: stivep on August 13, 2012, 08:09:20 AM
The mentioned above just expose level of  brain of f such individuals.
Level of processing, Level of understanding.
You have magician who knows how to make trick and he is in fear to accept big.....
like small time ?Joe Shmo who found spacecraft in his backyard and now he thinks how much alcohol he can  buy for it..
The FE arena is full of magicians but has TK earned his place in the top circle yet and financially gained from his presentation??
Hoppy
a.king21
Wesley: We had a plan for everyone to benefit. We had a manufacturing outlet set up in South Africa. Don't be so quick to criticise our plans, because you do not know then all. There is no mileage to be had in destroying the world economy. It would not benefit the poorest. On the contrary - many more would die if the global economy collapsed.
KP has consigned millions of Africans to poverty and he knows it.  That was the first thing Mike said to me when the deal collapsed.
Re your veilled allegations against TK: PM me.
Zeitmaschine
So the end of my comment is
HOW MONEY MUCH IS ENOUGH? ??? ??? ??? ??? ??
I'm easy to please. Never have to pay any energy bills would be enough money for me.
Quote from: Free.Energy on August 12, 2012, 11:10:15 PM
There is no spark because the energy is not built up high enough at this point in time.  The spark increases when the load is turned off in the 2012 video as the energy is building up faster since there is not load.  The spark is dissipating the excess charge.
This is most confusing. What is the purpose of the spark? To get rid of (or limit) the excess power (2012) or to get the device running in the first place (2004)? Maybe we should decide for one of them or for none of them.
And now another strange idea of mine, concerning the odd ground cables:
In the green box video the ammeter shows 23A going to (or coming from) the ground (faucet), but some say this is impossible. 23A is precisely the power that is required by the lamps. As far as I can remember this was the only measurement ever taken on the ground cable. But just in this green box video there is an additional car radiator buried in the earth and I couldn't figure out yet how this second ground is connected to the device. Therefore could it be that both groundings are connected in a way (at least during the measurements) that the current coming from the device runs through earth via both ground connections and only then to the lamps? Hence the energy is not coming from earth (like a Tesla transformer) but from environment (routed through earth unnecessarily) as TK stated in the video anyway?
Quote from: Shokac on November 24, 2010, 05:36:13 PM
In 100kW Kapanadze device don't have ground. Kapanadze says that in this device use Y-load 3-phase circuit, and center is N. (No Ground)
How could it be that one time no ground is needed at all (100KW device) but another time the whole amperage runs through the ground connection (5KW device)? Yes, that seems to be impossible.
So, leave out one more part: The dispensable ground connection.
My worktable looks more and more empty. ::)
Quote from: Jack Noskills on August 13, 2012, 07:52:12 AM
There is pressure of 1 uF at 1000 volts in one full sine wave, that would give 1 uF * 1000 * 1000 = 1 Joule. 1 joule for one second at 50 Hz would give me 50 joules, that is 50 watts. Don't think trafo cares if frequency is 50 Hz or 50000 Hz if core withstands it, so higher frequency should give 50 000 watts in this case.
Yet another (strange) idea of mine: What happens if an ordinary 50Hz transformer is operated with 50Hz grid frequency and, let's say, 5KHz high frequency at the same time by means of different primary/secondary windings? If there is a strong BEMF at 5Khz (square wave) in the core then (Rhythmodynamics again) this could influence the power consumption/flow of the 50Hz circuit, I guess.
But maybe something just blows up in plain view, not sure about that. ???
Anyway this would be in conformity with the patent drawings. Except the coils in the patents are not (in the presentations visible but phony) air coils but (hidden) ordinary 50Hz transformer coils. The right side coil is connected in series (choke) with the 50Hz inverter (blue box) and the load, the left side coil is connected to »something« that provides high frequency (not necessarily high voltage) for powerful BEMF creation. If this is Tesla stuff, then which Tesla patent could come into question here?
Quote from: T-1000 on August 13, 2012, 03:27:01 AM
The principle is simple: mix reactive current with BEMF voltage and they sum up.
Make it so.
a.king21
Getting back to science: I think the forum can now accepts where we have to target our research.
We need to know more about generating 3 phase solid state.
We know that the Kapanadze secret is just about transformers.
His circuit L1 is the classic prerequisite for ferroresonance.
Now maybe you can understand my interest in Jack Noskills, and my appreciation of Zeitmachine's logical thinking.
The Henry Moray picture is also a usefull posting.
It is possible that a pseudo ferroresonance exists in an air core situation. That is where the experiments should be directed.
If TK can stumble on this, then so can we.
If you do find the secret, then I can also offer you a commercial outlet also, and all the forum can benefit.
There are 7 billion customers and a handfull of researchers. There's enough business for us all.
I strongly suspect an asymmetrical toroid. Maybe one with two different hemisphere cores. Say one of ferrite, the other of iron.
