0 Members and 234 Guests are viewing this topic.
T-1000
Quote from: frantz on August 13, 2012, 04:46:19 PM
Ok,  As you can to see, current going in the same direction, always the same. As we know EM field is a combination of two fields like magnetic and electric. Whats happen when we will add external static electrostatic field around second transfotmer?  I think, we will extend one component of EM field like electric field and we will increase voltage on output with the same current which we have (increased from transformers circuit).   This is a idea only.
I will remake question:
What will happen in transformer output with 2 primaries and one primary is like in current transformer for few amps+ very low volts low frequency sine wave and secondary primary is high resonant frequency of transformer and high woltage spikes + micromaps and on 180 degrees phase to sine wave of first primary?
P.S> If you try that in simulation it won't give you answer because this is outside of conventional model.
frantz
Quote from: T-1000 on August 13, 2012, 05:07:05 PMI will remake question:What will happen in transformer output with 2 primaries and one primary is like in current transformer for few amps+ very low volts low frequency sine wave and secondary primary is high resonant frequency of transformer and high woltage spikes + micromaps and on 180 degrees phase to sine wave of first primary?P.S> If you try that in simulation it won't give you answer because this is outside of conventional model.
You are talking about the different circuit...
I don't want to use HF only + static electric field from tvs...from colour tv set for sucking electrons....
that's all.
T-1000
Quote from: frantz on August 13, 2012, 05:21:19 PM
that's all.
Not really :)
The static field from ТÐ'С is very similar to magnetization of transformer in one primary just at much less intensity.
frantz
T1000  Did you saw how look signal from colour tv set after multiplier on oscilloscope?  This is DC not pulsed DC.    I'm talking about hot wire not about core.  But this is not important. In my idea we can use both DC or pulsed DC. Most important is potential (+)!
elementSix
John Hutchison effect  He uses 3 tesla coils, wired so that they  do not through off sparks.  He has wired a RF generator into the large coils and it creates a large field and runs 2 different frequences into the field and gets all different effects from antigravic effects, things disappear and it also taps into the either energy field and can become self sustaining .  He also uses a static generator in some way to enhance the field.  TK might be using the spark GAP TO CREATE the field and runs 2 different frequency thru the coil and taps into the either.  I'm just talking out loud but that toroid he saw in the new video might be the key.
 TESLA claimed that you need mica capacitors that are necessary for a free energy device.    They have a special resonace that is needed to achieve the process of gathering the either.
