0 Members and 441 Guests are viewing this topic.
frantz
Guys, what about we are talking?  I'm writing about Jacks circuit with small addition component, that's all.  And again we have so many coils, few hf, etc.  Lets focus on small things. I'm not a Tesla genius and you, too.  I would like to find answer for simple question.  Whats happen when we summarise two electric fields from different sources...?    One source is weak, second is strong.   In my opinion magnetic field in coil response for amperage, electric for voltage. And lets play.    And I see two ways for increase the power in coil, adding one of them from external resonant circuit.
For increasing current I putted scheme of idea few pages ago. For increasing voltage I'm thinking now. And I think the rule is the same but with voltage...;-)
Magluvin
Quote from: frantz on August 13, 2012, 03:08:41 PM
in regarding to the Jacks transformer:
this is a Java simulator application:
http://www.falstad.com/circuit/
between the lines you have code to import into this app
$ 1 5.0E-6 20.712724888983452 23 5.0 50
T 144 224 256 336 0 4.0 1.0 -28.783634378696526 28.738547635144172 0.999
T 416 160 512 256 0 0.001 1.0 28.73854763514417 3.8839819695951094 0.999
v 80 224 80 336 0 1 50.0 230.0 0.0 0.0 0.5
r 576 160 576 256 0 1.0
w 80 224 144 224 0
w 80 336 144 336 0
w 256 224 416 224 0
w 416 224 416 256 0
w 416 160 416 128 0
w 416 128 544 128 0
w 544 128 544 256 0
w 544 256 512 256 0
w 544 256 576 256 0
w 256 336 512 336 0
w 512 160 512 336 0
w 512 160 576 160 0
o 2 64 0 35 320.0 204.8 0 -1
o 3 64 0 35 40.0 51.2 1 -1
lets watch what happens in second transformer, I mean about current direction.
Its very interested.
As you can to see , there are no diodes... :-)
Question to all: Do you see a way to strengthen the signal in second transformer?
Hey Fr
If you right click the scope  shots you can select power consumed for the source and the load.
In your sim, I see about 14.5 kw out of source and about 12.5 kw back to source, which leaves about 2kw being actually taken from source.
The 14.5kw is for half of the input cycle and the 12kw is during the other half of the input cycle. So we can say 14.5kw out and 12.5kw back in, to the source.
Now, the output to the load is 1.4kw during each half cycle of input.
During the 14.5kw half of the cycle, we can shave off 1.4kw that went to the source as desired, so 13kw is stored in the circuit at the time.  Then during the phase of the cycle that sends 12.5kw back to the source, we ware also seeing 1.4kw being used at the load.
So during this 12.5kw back to the source stage, if that 12.5kw is being sent back to the source, and the load is receiving 1.4kw, then we have to consider the total stored is 12.5kw +1.4kw =13.9kw.    So it might look like .9kw is extra, being that we figured only 13kw stored from the initial cycle.
lol this will need some deeper analysis to determine if there is extra energy there.
Mags
frantz
I don't think so.  maybe a little increase but it is not enough.  You must remember this simulator don't take internal resistances of coils etc.   We need something more, some external factor X... ;-)  read above.
Magluvin
Quote from: elementSix on August 13, 2012, 05:44:11 PM
John Hutchison effect  He uses 3 tesla coils, wired so that they  do not through off sparks.  He has wired a RF generator into the large coils and it creates a large field and runs 2 different frequences into the field and gets all different effects from antigravic effects, things disappear and it also taps into the either energy field and can become self sustaining .  He also uses a static generator in some way to enhance the field.  TK might be using the spark GAP TO CREATE the field and runs 2 different frequency thru the coil and taps into the either.  I'm just talking out loud but that toroid he saw in the new video might be the key.
 TESLA claimed that you need mica capacitors that are necessary for a free energy device.    They have a special resonace that is needed to achieve the process of gathering the either.
I have read that Tesla highly recommended mica for caps, but I never read that mica had any special resonance effects.  Can you post a link to those comments by him. ;]  Im sure that mica was the best material that he could come up with at the time(back then), but im also sure that there are new materials that can come close or better these days.  And with Nano tech, things are going to get crazy. ;]
MaGs
frankidel
hi, just a thought, we are talking of the transformer ( 220 to HV ) could you use it as a tesla coil, or in a way to wire it like a tesla coil. or transmitter avec receiver in the same time ...
