0 Members and 215 Guests are viewing this topic.
frantz
Quote from: Jack Noskills on August 14, 2012, 04:32:38 AM
This simulator is not accurate enough. It does not care about frequency that drives the coils, hence it cannot simulate the high impedance effect that driving frequency creates which is needed for this to work. In my tests if I used pressure of 40 watts, that I could take without consuming source, if I used 1 watt then I could take only that.
In this simulation there is 14 kw coming in but only fraction of it is consumed so it is not correct. What you can consume depends on the core, how much it can create. If that is exceeded only then it draws from the source.
Is there a simulator that understands frequency and its effects in an inductor correctly ? Can anyone test this if such a simulator exists ?
Jack,
you have a absolutely right. I gave link to this simulator because I wanted to pay attention for behaviour of current inside second transformer not for power gain or other things. As we know every one coil can resonate on some frequency without cap because have self capacitance and resistance. In this simulator is not possible to see this phenomena.
In my opinion is very interesting the phenomena with currents in second transformer. Rectified current without diodes! wow
But on output we still have AC signal...  :)
Remember, I don't want to destroy your idea because is very interesting and brilliant in its simplicity.
a.king21
A close up of the earth lead and spark plugs in 2012 aquarium 2.
a.king21
Zeitmachine: Re grounding. I have spoken to TK about this in many different ways. The conclusion is that it is a standing wave mechanism, first discovered by Oliver Lodge in the 19th century. It may have several functions. By experimentation it has been shown to keep your device in phase. In other experiments it can double the power in your device. The grounding can be replaced by the negative terminal of a car battery.
leo48
In my opinion the earth is only necessary for personal safety because your device has high voltage circuits   8)
Leo48
Every problem has always at least two solutions simply find
The strength of the strong is the ability to navigate struggles with eye serene
captainkt
@leo48, If only as regards to grounding. Some of the worst shocks I have had were from high voltage to earth, no earth no shock. When using high voltage the earth needs to be out of the way and keep one hand behind your back. Note in the green box video the bulbs only glowed with a poor earth via radiator, then when connected to good earth(water pipe) full brightness. In my opinion the grounding is a vital part of circuit, resonance to earth etc.
Keith
