0 Members and 58 Guests are viewing this topic.
cheappower2012
You guys are still locked into its a tesla
invention,this type of device needs no ground thats a trick.
As was said of SM by Jack Durban,"he lies even when he doesn't need to".it applies to TK also.
In my opinion the 3 phase transformer is the source of overunity
this explains also why the turkey people were not able to reverse engineer
the turkey device.This also explains why a 10kw 3 phase system was offered to
a.king21,to produce more power it requires a bigger 3 phase transformer.
In my opinion the reason why TK did not want a.king21 using heat sensing equipment around
the device is this,the secondary windings when in operation pass greater amounts of current than the ratings
of the wire can pass this causes a heating up of the secondaries,so a heat sensor would show this,
and point to the transformer as the source.The device should burn out the secondaries after the device has
run for a very long time,due to this.Here is something to ponder,the transmisson of energy over a wire of a small size,2kw in this case,can not ever be except if the voltage is very high,remember this transformer was designed to operate at 50 Hz/60hz,230vac possibly 400vac
it can not operate at high frequencies.Take your choice fraud by hidden wire,batteries or real but unknown ,against conventional theory,a small gauge
wire passing very high current beyond its rating.
x_name41
frantz
Quote from: cheappower2012 on August 14, 2012, 09:43:50 AM
I thing you should to have right.
1. Green transformer can't to be load by HV - isolation is calculated for 600 maybe 1000V
2. wires are connected to green TR are insulated with ordinary insulator for few hundred V. And colour one are glued together with ground cable. Electrical breakdown was not inevitable. White wires are so close ....
Free.Energy
Quote from: a.king21 on August 14, 2012, 05:49:36 AM
Zeitmachine: Re grounding. I have spoken to TK about this in many different ways. The conclusion is that it is a standing wave mechanism, first discovered by Oliver Lodge in the 19th century. It may have several functions. By experimentation it has been shown to keep your device in phase. In other experiments it can double the power in your device. The grounding can be replaced by the negative terminal of a car battery.
This is a very definitive statement and Tesla said the same thing in patent 685957, Apparatus for Utilization of Radiant Energy.
This means some things:
1. TK shows many extra components that do nothing and laughs at us.
2. The real device is in the black box and must be as simple as the examples shown in Tesla Patent so TK hides this.
3. Three phase transformer is not source of OU.
x_name41
http://www.overunity.com/7679/selfrunning-free-energy-devices-up-to-5-kw-from-tariel-kapanadze/dlattach/attach/113776/image//
In the picture this is not were wires!
