0 Members and 379 Guests are viewing this topic.
Free.Energy
Quote from: frantz on August 14, 2012, 10:50:04 AM
Guys,
we are talking about tiny wires....
But it is possible, TK can use cable which looks like the ground cable and connect  it to the phase inside black box. Rest of wires are fake.. :)
Watch, ground cable have silver colour, but this, inside near green transformer, have copper colour and going inside tube of blue coil....
Maybe some where is second one (silver).
I thing, whole power generation is inside of a black box.
As I told previously, Th shows only this what we should to see!
I agree.
Hoppy
Guys,
IMO, the earth wire is acting as his grid neutral. The live wire is thin and yet to be detected. He may be somehow offsetting the load on the thin wire with an inverter fed from batteries in the black box. That's as far as I'm willing to speculate at the moment.
frantz
Quote from: Hoppy on August 14, 2012, 11:08:29 AM
With battery? I don't think so. Like a.king or Mike told the weight of device was around 6 - 8 kg. Good battery have few kg.
I think, there must be capacitors bank. Capacitors are slight. And few mF (maybe 10 - 20mF) should be enough for 2 sec. powering after switching off.
base of the generator must have a high current efficiency and Cap bank is only to temporary put energy to stabilize the current on output.
Caps should be charged like in pulse power supply. And we have OU pulse power supply... ;-)
verpies
Quote from: a.king21 on August 13, 2012, 12:57:26 PM
We need to know more about generating 3 phase solid state.
Low frequency 3-phase driver is trivial and so are 3-phase transformers.
The most efficient method for making a 3-ph driver I know, is described by an electronic Guru at tinaja.com in the Magic Sinewaves articles.
Interesting question to ask is why is 3-phase electric current important at all?
A possible answer might be: "because it can create a very nice rotating magnetic field".  Such fields have many interesting properties when the Lorentz force is considered and also are good for stimulating NMR.
P.S.
2-phase electric current can create rotating magnetic fields too, when it is 90-degrees out of phase, albeit not so uniformly - that's why 3-phase driving is preferred for BLAC motors.
