0 Members and 293 Guests are viewing this topic.
Hoppy
Quote from: verpies on August 14, 2012, 12:39:57 PM
Maybe. Ferroresonance is still a weakly understood phenomenon.
Often it is associated with a magnetic field varying independently in two or more dimensions.
The attached article states: "Ferroresonance is a widely studied phenomenon but it is still not well understood because of its complex behaviour."
This is what Wikipedia states about ferroresonance.
"Once the ferroresonance has appeared, the system stays working under ferroresonance, until the source is not able to provide the necessary energy to maintain the phenomenon." Where is this source of energy in TK's setup? Is it being seriously suggested that we can produce the energy source from a set of batteries to allow ferroresonance to manifest and then hold and carefully control this condition for 4.5hrs @ 2KW with the same set of batteries??  ::) that's assuming we have some batteries to begin with???
Hoppy
Zeitmaschine
Quote from: a.king21 on August 14, 2012, 05:49:36 AM
The grounding can be replaced by the negative terminal of a car battery.
Where is the car battery in 100KW device?
Has anyone measured the amps of the grounding of the aquarium II device? I can't imagine concrete is a good conductor.
Anyway, Free Energy for dummies:
http://purco.qc.ca/ftp/Researchers/Free_Energy_Plans-1.pdf
The interesting term here is »Back EMF«. And maybe it worked, because the official website is offline already. :D
Farmhand
Just throwing this out there, I think I could demonstrate the results of the garden video
with the car radiator.
1. Firstly the neutral wire of the mains is connected to the water tap/water pipe for one ground wire. ( the tap wire )
2. Secondly an active wire from the mains is previously buried in the garden below where the radiator is to be buried
maybe connected to a conductive plate. The radiator wire.
3. When the radiator is watered in  well a low resistance path is created between the buried wire and the radiator with the wire
connected to it.
4. Take both wires to the demonstration bench and connect them with an assistant observing from the flat/house.
5. On a given signal the assistant flips the switch to energize the radiator which powers the lights however is desired.
6. The battery shown could be recharged by the mains while doing it.
Anything can be faked.
Will someone pay me to demonstrate it ? I could do with some money for equipment to experiment.
Cheers all.
verpies
Quote from: Hoppy on August 14, 2012, 12:34:25 PM
It depends on what type of batteries he could be using
Did you pay any attention when I calculated how much mass and space the best batteries would need to occupy in order to power a heater for 4.5h @ 2kW ?
The best batteries available today would take up 7.5 Litres of space (weighing 18kg) !!!
verpies
Quote from: frantz on August 14, 2012, 10:50:04 AM
But it is possible, TK can use cable which looks like the ground cable and connect  it to the phase inside black box. Rest of wires are fake.. :)
Yes, it is possible.
Only few hair-thin enameled wires would be required to deliver 2kW when using an external 3kVAC power supply.
