forest
I will tell you a little more : if this man on video touching ground rod is the man in every presentation helping Tariel then I assume he knew the device and has some quite good probably electrical practice. Do you think he is faster then the electric current , that's why he touches this rod in fast attempts ? I remember when I was young , very young I thought I could be faster then electric current  :o ;D ;D ;D ... or maybe there is much simpler explanation, huh ! ??
jbignes5
For all of you yelling this is not a Tesla technology have never read anything on Tesla. Period.
What about the hairpin experiment? Don't you think the heavy copper coil is exactly that? Just like in the hairpin experiment there are nodes setup on the heavy copper bar. This is where the energy is coming from, plain and simple. It's is so simple a common man figured it out.
So lets continue with the actual reading of Tesla so we can understand these very high voltage pulses and how they react with masses of copper. It is the very sharp pulses that is the magic. It draws in or attracts current from the air which is everywhere in our atmosphere. The energy is all around us yet we take this one fundamental fact for granted. Great flows are continually in movement and all we need to do is open our eyes to harness them.
Through the greed of the powers that be they keep us blinded to the fact that energy is everywhere!
Tesla was working on a motor generator which he likened to a transformer. It was a steady state device once started and when you tried to stop it it created huge amounts of current from the rotor cutting the lines that were being injected into the rotor core. It was the special motor/generator he had Westinghouse build for him in 1932. He went back to this design because his wireless was shut down by J.P. Morgan and destroyed by the American government. Morgan was a very powerful man. He was a banker and owned the government basically.
The simple design was a high voltage magnetic generator that fed high voltage coils on a thick piece of Bessemer steel(Iron really) as the field coils. The Iron was to keep the magnetic field inside of field coils so that the high voltage pulses could act upon the heavy copper coils in the rotor. The steady state part of the motor/self excited generator worked much like a synchronous motor. There is still a magnetic field in the Iron core of the field coils. The rotor tends to synchronize with that magnetic field of the iron core. When you retard the rotor by the use of a clutch and drive train it slows down the rotor and more high voltage lines cut the rotor windings creating a huge current which is fed to the motor part of the device and a load if you want. Tesla directly contributed this whole process to a moving transformer that could generate it's own current without much of an input. Since the field coils are modeled after the AC system it allows for a continuous rotary movement of the field coils which will generate current in the rotor coils. To start the process, all one would need is a source of voltage like a 12 volt battery and then boost it to the appropriate voltage to kick start the process.
Here is the patent for the Improved AC system Tesla tried to implement after making the mistake of basing it off of current and not higher voltages.
[size=78%]http://www.teslauniverse.com/nikola-tesla-patents-390,721-dynamo-electric-machine[/size]
Now pay attention to he descriptions of transformers, also look at the date. Now insert higher voltages around the rotor and you can see how it works. You need all parts of this to work at all. Except for the lower transformer which is an alternate loading transformer.
What is needed is the exciter, the generator and a prime mover(motor). That alone will net you a steady state motor that could be used for cars with plenty of room for all the loads associated with driving vehicles with nothing more then a battery to kick start it if it is shut down.
There are plenty of references to the pulsed high voltages and the effect they have on metals written by Tesla. It is said he had to have a very large fan on the front of this motor he had in his roadster experiment. This was to strip off the heat that formed in the rotor because of the effect of this high voltage pulses had on the thick copper wires in the rotor. Aluminum would instantly flash and destroy itself when presented to this system.
Here is Tesla talking about these effects:
"Of all these phenomena observed with currents, or electric impulses, of high frequency, the most fascinating for an audience are certainly those which are noted in an electrostatic field acting through considerable distance, and the best an unskilled lecturer can do is to begin and finish with the exhibition of these singular effects.  I take a tube in the hand and move it about, and it is lighted wherever I may hold it; throughout space the invisible forces act.  But I may take another tube and it might not light, the vacuum being very high.  I excite it by means of a disruptive discharge coil, and now it will light in the electrostatic field.  I may put it away for a few weeks or months, still it retains the faculty of being excited.  What change have I produced in the tube in the act of exciting it?  If a motion imparted to the atoms, it is difficult to perceive how it can persist so long without being arrested by frictional losses; and if a strain exerted in the dielectric, such as a simple electrification would produce, it is easy to see how it may persist indefinitely but very difficult to understand why such a condition should aid the excitation when we have to deal with potentials which are rapidly alternating."[/size]
[/size]
"[/size]One reason, perhaps, why this brand of science is being so rapidly developed is to be found in the interest which is attached to its experimental study.  We wind a simple ring of iron with coils; we establish the connections to the generator, and with wonder and delight we note the effects of strange forces which we bring into play, which allow us to transform, to transmit and direct energy at will.  We arrange the circuits properly, and we see the mass of iron and wires behave as though it were endowed with life, spinning a heavy armature, through invisible connections, with great speed and power with the energy possibly conveyed from a great distance.  We observe how the energy of an alternating current traversing the wire manifests itselfâ€"not so much in the wire as in the surrounding spaceâ€"in the most surprising manner, taking the forms of heat, light, mechanical energy, and, most surprising of all, even chemical affinity.  All these observations fascinate us, and fill us with an intense desire to know more about the nature of these phenomena.  Each day we go to our work in the hope of discoveringâ€"in the hope that some one, no matter who, may find a solution of one of the pending great problems,â€"and each succeeding day we return to our task with renewed ardor; and even if we [/size]are[/size] unsuccessful, our work has not been in vain, for in these strivings, in these efforts, we have hours of untold pleasure, and we have directed our energies to the benefit of mankind."[/size]
[/size]
This is just a few tid bits from Tesla and others. As for the few who don't read all that there is to know about this effect, you will always be lost and grasping for crazy explainations of what is being seen by experimenters like TK.[/size]
[/size]
TK's effect is nothing other then harvesting the emissions from a disruptive discharge(spark gap) It energizes the inner coil and creates nodes along the wire of the coil. Instead of shorting it out like Tesla did in the hairpin experiments he lets them add together like stringing batteries together in series and adds in current by having the wire loops close together or parallel battery connections.[/size]
[/size]
It's simple really but then again we have had this information held back from us through years and years of the powers to be teaching only one side of the equation and ignoring the other side because it brings power back to the individual without reliance on the system they created. Read and re-educate yourself to the true reality. Stop being lazy and relying on others to do it for you. Because they will always lie to you.[/size]
Hoppy
Quote from: a.king21 on August 14, 2012, 03:41:36 PM
Some more photos from slightly different angles.
What is the short length of what looks like blue cable on the RHS of the box in photo 2? is it a visual marker for a thin wire?
Hoppy
a.king21
jbignes 5 No-one is denying Tesla technology.
Tariel does not use it that's all. The spark gap in both aquarium videos is used as a load limiter. Kapanadze has other builds with no spark gap at all. He simply wanted to fool us all. We know the TK build is some kind of transformer.
The rest is smoke and mirrors.
andrea76
Quote from: a.king21 on August 14, 2012, 03:15:14 PM
I had a long conversation with Mike today. They handled the earth wire on numerous occasions.  Also look where it is connected inside the box. I welcome all discussions, but I do not think it is the earth wire. Mike said it was very tiny. And remember it was disconnected for a few seconds. Whatever he did we don't think it was the earth wire. My money is on an asymmetrical toroid. Also ferroresonance, but not conventional ferroresonance. Remember in the patent he loops the input to the output. Lets say pseudo ferroresonance. Anyway if anyone can clean up the photo - it might prove usefull.
About the ground wire (probably for prevent the lightning strike of the high level of energy of the conversion process-ions into electrons) see the document at http://www.scribd.com/doc/53746495/Bob-Boyce-TPU
