cheappower2012
To all,a.king21 answered my question,I accept it,case closed!
@Bernhard
How did you find out this information,great work!! :)
Very important information,that's needed to solve this puzzle
sparks
Quote from: jbignes5 on August 14, 2012, 05:17:31 PM
The process can be done without spark gaps. Tesla said that himself. The spark gaps are easier low tech way to get the sudden discharges needed for the energizing energy. In fact Tesla said that he could use a great many gaps and there would appear to be no spark between them and still got oscillations. So the spark really isn't the key. It's what is going on within the transformation. If you include Iron it messes it up severely.
Although Iron has it's merits even if it retards the flow of the magnetic portion of the fields. Like in the motor/generator setup he uses it to get near synchronizing of the rotor to the field present in the iron field core to the rotor. The field coils are very important and the prime mover rotates the heavy copper on the rotor through this rotating field breaking the synchronicity and doubles the generating speed.
Along the same lines Iron has a way of staying magnetized per Leedskalnin especially when it is in a circular path(PMH).
Think about the PMH for a moment and you can see where I am going. When the PMH is in operation it holds itself together with great force right? Well wouldn't that magnetic force still be present even if there was no break? In effect you would charge the ring up and use the electric field to grab and manipulate the magnetic field for very little cost... Kinda like squeezing a ring hose and rotating the squeezing points.
Also at some point someone changed the angle that the field coils are oriented. Looking at modern designs and Tesla's designes they changed the angles of the filed coils. Tesla's is oriented 90 degrees and most motors'generators field coils now a days are oriented 45 degrees and they don't go around the field core either. Where Tesla's designs are vastly different almost always en-circulating the field cores.
They have designed inefficiency into the current motors/generators of today to sell more current and make it more valuable.
This deviation from the old ways has deluded us into a false teaching about "electricity" and it's effects. There is more then the magnetic field and up until recently there are some that are rediscovering these facts. The exciters being the biggest rediscovery in my honest opinion.
The reason this has been shelved is because it was associated with the static form of energy and was put in the same space as static electricity. We never explored that area because it was thought as a destructive nuisance. Nothing could be further from the truth. In fact I would say it has everything to do with "free" energy and life itself in all forms to even the mechanics of planetary bodies.
   Tesla's original AC motors were wound around the core.  The only time I ever wound a wire around the core of an ac motor stator was to test it for damage.  You would hit it with hf pulse and watch the echo for eddy current loses due to lamination damage.  Jbigness pickedup on the same thing I did and that is Tesla wound his winding around an annular laminated ring.   I always thought they moved them to face mount so the current outside of the core wouldnt be waisted.  Now I see how it wouldnt be waisted if your trying to produce an actual magnetic wave throught the ring.  HMMMM.  I actually repaired one of Westinghouse's first commerical ac electric motors.  It was single phase.  It used inductors to get the phase shift instead of capacitors.  Capacitors were a big problem back in the day.  Tesla designed a dynamic capacitor in his parametric oscillators.  TK clearly demonstrtes this when he self=runs.  What appears to us as an electrostatc field is actually an electromagnetic wave of ultraultraultrahigh frequency.  It's static preponderonce is simply because it propogates the time dimension therefore remains static in the time dimension because it is a piece of the fabric of spacetime.  Moray a student of Tesla used standard demodulation circuits to bring it on down.  He called it the Universal frequency.  His book is a good one to read.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
Bernhard
cheappower2012 :
I found it at myself in a cellar, after search on the internet that is the power source module from the prehistoric USSR computer ES http://en.wikipedia.org/wiki/ES_EVM
cheappower2012
@Bernhard
This is a very important part,do you have a schematic of the transformer.
The important information needed,weight,size,schematic,composition of core
it doesn't look laminated,is it solid core.You need to take ohm readings if you don't have excess to a schematic of the transformer.
great work!!
frankidel
Hi Aking, another thing, in the green box interview, kapanadze said that it could be built for around 400 $ ( maybe us ) so i think it has no expensive parts at all.,
