0 Members and 297 Guests are viewing this topic.
Bernhard
@cheappower2012
core laminated ferromagnetic tape ๏̯͡๏ ,
tomorow reply becose night and going to sleep
a.king21
Quote from: frankidel on August 14, 2012, 09:06:19 PM
Hi Aking, another thing, in the green box interview, kapanadze said that it could be built for around 400 $ ( maybe us ) so i think it has no expensive parts at all.,
Exactly, that is why we were interested. What TK doesn't realise is that he has serious competition. His only advantage was price. If solar panels drop to 10% of today's price he's finished. We know manufacturers are working on it. Once the e-cat comes out (I've ordered 3 of them)  he's finished. Simple.
I wonder how many  of us would be interested if we could heat our homes for 20 dollars a year (e-cat).
Not only that, the device is designed to replace central heating boilers, so any plumber could fit one in an hour.
What makes me annoyed - apart from the fact he scammed us - is that this is 19th century technology and we can't find his secret... yet!  That's why I've told this forum everything I know - so we can get on and do the correct research and not be mesmerised by spark gaps (as I was for well over a year). Let's try and understand Jack Noskills's development. There have been some weird effects discovered by well known researchers. In fact if  you turn Noskills circuit upside down it is very similar to Kapanadze's patent if you ignore some additional components.!!!!!
Jack Noskills
Simple way to test if high frequency AC works is to use neon sign driver similar to what Don Smith used. This you would connect to second trafo, at the load there would be step down trafo to get back to proper voltage level.
You will need to find out the amount of wire to use in the coils and also amount of wire in the stepdown trafo. I have written instuctions how to do it, I do not want to repeat my self here. If you are interested in doing the experiment and need more info then just PM me for any questions. You will need NST (or any other high frequency AC source) and two ferrite rings/rods for the experiment. Third core might be needed in case there power is fed back to source, or spark gap as an easy way, between NST and second trafo. It would also be interesting to see what happens with iron core when used as the 'second trafo', the one that has two coils connected together.
forest
Quote from: sparks on August 14, 2012, 08:43:21 PM
   Tesla's original AC motors were wound around the core.  The only time I ever wound a wire around the core of an ac motor stator was to test it for damage.  You would hit it with hf pulse and watch the echo for eddy current loses due to lamination damage.  Jbigness pickedup on the same thing I did and that is Tesla wound his winding around an annular laminated ring.   I always thought they moved them to face mount so the current outside of the core wouldnt be waisted.  Now I see how it wouldnt be waisted if your trying to produce an actual magnetic wave throught the ring.  HMMMM.  I actually repaired one of Westinghouse's first commerical ac electric motors.  It was single phase.  It used inductors to get the phase shift instead of capacitors.  Capacitors were a big problem back in the day.  Tesla designed a dynamic capacitor in his parametric oscillators.  TK clearly demonstrtes this when he self=runs.  What appears to us as an electrostatc field is actually an electromagnetic wave of ultraultraultrahigh frequency.  It's static preponderonce is simply because it propogates the time dimension therefore remains static in the time dimension because it is a piece of the fabric of spacetime.  Moray a student of Tesla used standard demodulation circuits to bring it on down.  He called it the Universal frequency.  His book is a good one to read.
You pointed to the correct answer.Almost. I think it is longitudinal wave.The truth is : there is a lot of energy there. The man in video behaviour : https://www.youtube.com/watch?v=tJ7tqVXa-PQ
