0 Members and 121 Guests are viewing this topic.
Frederic2k1
Quote from: a.king21 on August 14, 2012, 04:09:54 PM
jbignes 5 No-one is denying Tesla technology.
Tariel does not use it that's all. The spark gap in both aquarium videos is used as a load limiter. Kapanadze has other builds with no spark gap at all. He simply wanted to fool us all. We know the TK build is some kind of transformer.
The rest is smoke and mirrors.
You cannot know for sure if the spark is not hidden in one of the green or black boxes. So I would be careful when you make such statements that the sparkgap is only there for load limiting.
Bernhard
@Collapsingfield
I dont have LC-metr in this moment  :-\  only miltimetr
Ok, i'm connect transformer ecsacly you write on pin Nr 1-2 ~80Ω
pin Nr 1-2 in AC 50Gz ... 12V /24V / 36V
then on a pin Nr 3-4 ... 1,8V / 4,0V / 6,1V
,and on a pin Nr 5-7 ...  0,5V / 1,2V / 1,9V
Collapsingfield
@Bernhard, thank again. It is very useful. Let me ask some more measure. One AC signal is enough (24V for example), but you should measure the voltage on the other coils (all the 8 ) as well, not just on the same core.
a.king21
The reason I deduced that the Kapanadze device is not a spark gap induced Tesla coil is because of the infinity loop which Kapanadze uses.
I did extensive experiments on infinity looping and found that no matter how much the spark gap speeds up it always acts as a limiter. When the spark gap ceases to act as a limiter - which is what you want in order to start the infinity loop process, then the production of power stops at the same time. I then analysed the spark gap rates in the videos we could obtain publicly and found a direct corelation between power out and spark gap firing. The 2004 video uses a different system. There the spark gap is used as an indicator that the process is working. In one patent Kapanadze uses the spark gap to power his frequency generator. In another patent he uses the spark gap as power limiter. Because he generates his OU through a transformer  anomaly he can do anything he wants until we figure out his secret transformer. He could power a laser beam and point it at a coil and say that is where the secret lies. Anything is possible in the smoke and mirrors department, once you have "free" energy. If none of us had ever seen a solar panel before, we could easily have been fooled. He could have called it a cosmic antenna for instance.
In my discussions with Kapanadze I told him that I had seen through his spark gap Tesla ruse. He was not amused. He initially tried to sell us on a hydro-mechanical device. I said it was smoke and mirrors - he was not amused. I think he got to respect my knowledge of his devices after a while. In the 2012 Aquarium 2 video our team were well aware of the spark gap use as a limiter - hence no contradiction from the Kapanadze side when our team figured it out and mentioned it. In fact one of Kapanadze's team even agreed and pointed out the thermal cut out device on the radiator.
The wiser replicators will heed my scientific deductions and hopefully not be misled by all the smoke and mirrors stuff. That is why I am interested in Jack Noskills's discovery of transformer anomalies. You might also want to look at Peter Lindemann's transformer anomaly with the water spark gap experiment. It has overtones of Jack Noskills except Lindemann uses a diode and a HV coil. The principle may be connected.
27Bubba
OK. I have found a transformer to conduct my experiments. Will it work?? ;) :D ;D ;D
ps. Check out the stick electrode holder.. What his chances of not getting killed?
