Zeitmaschine
Try someone this impossible circuit or any variations of it. And then please tell me if this does not work, so I can save my time building it. ;D
Thanks
T-1000
Quote from: Bernhard on August 15, 2012, 12:09:38 PM
Ну если Ñ,уÑ, по русски понимаюÑ, Ñ,о небуду ломаÑ,ÑŒ язык и я ã‹¡
Labas,
You better write in English because google translate makes fun out of Russian and our language in a way nobody can understand. :)
Quote from: Zeitmaschine on August 15, 2012, 02:00:14 PM
Thanks
http://www.youtube.com/watch?v=66-DV9kY2dM - You might try this setup first. Attach choke with capacitor in series and make voltage and current phase different close to 90 degrees first. Then attach 2 ampmeters on power transformer before them and see current difference in each ampmeter results. This is where it goes outside of conventional model.Then find maximum current and lowest voltage betwen ampmeter which shows more amps and choke windings. There will be your load output. Then attach high voltage high frequency source of BEMF spikes to that place with 180 degrees of current phase and keep it always in sync...
P.S> Someone could translate this part of video, there are very important bits of information. And the last part of video got self runner demo.
Bernhard
@T-1000 LT: ... Sveikas, irgi esi iÅ¡ Lietuvos ã‹¡ tai kad koks skirtumas kuria kalbÄ... raÅ¡yt, viska bandau nupieÅ¡ti/nufilmuoti ant schemų/paveiksliuku/video ir t.t. -> kad bÅ«tų aiÅ¡ku ir kiniečiui ir afrikiečiui be žodžių ã‹¡ Å¡iaip esu dizaineris tai pripratau kad meno kalba suprantama be žodyno ã‹¡
EN: Photoshop retouching helping open eyes and seeing through plexiglass ๏̯͡๏ whether recheck correctly I draw the scheme circuit ๏̯͡๏
RU: ФоÑ,ошопное реÑ,уширование помогаеÑ, оÑ,крыÑ,ÑŒ глаза и посмоÑ,реÑ,ÑŒ сквозь блики оргсÑ,екла ๏̯͡๏ вроде сÑ...ему правильно накидал, перепроверьÑ,е  ๏̯͡๏
cheappower2012
@bernhard
Good job,do you have a schematic of the power supply,
from what you posted the power supply is 200 watts,if so its
impossible for it to source the power to lite the heater 2kw,this is the right direction.
The schematic is only needed to verify that this
transformer was made to operate at 50 hz/60hz only.
x_name41
