Hoppy
Quote from: v8karlo on August 16, 2012, 04:59:01 PM
Sometimes for A reading attach small car lamp 12V, 1A and measure in series,
just to have any load and at 1200V setup I measured 550-600mA, but often I just
do it without load and than is 900-1100mA (1.1A).
I am playing with this toy for to long and I am not interested in discovering
anything about cap coils because after so many experiments I know all about
them.
What is interesting to me is what Kapanadze is doing to his coil to gain so many
amps , and yes, his coil is capacitive, but one is longer than other so current tend
to go in one direction and he dont need output diode.
The output of my coil is direct pulsed current.
Interesting indeed, as according to TK's measurements he is pulling over 20Amps from the ground to run the 2KW electric fire as he has little or no internal power supply!
v8karlo
Here is original setup, easier one without backfeed and
driving coil.
Driving is directly through one of cap coils, doesent matter
which one in this setup.
When 3rd driving coil is present then it does matter which
cap coil is going to output diode and be output minus.
And sorry, I just left to my lab (so call  it) to test it and got
900V on ferrite rod. Last time I tested this original setup was
on laminated cores, thats why I remember lower voltage.
This original setup is very easy to test. Just hit it with 20 or so kHz,
and adjust Duty C. until voltage raise.
My output cap is M.Oven 2000V, 2uF because when I press off
button voltage drops slowly to 0 so I know that V-meter didnt lie to
me.
Kator01
V8Karlo,
why do you think, that your digimeter shows the correct amperage at the output ? at 22 KHz ? It was shown by itsu in one of his vids, that any values measured by standard-digimeters at these frequencies are cmpletely wrong. What kind of digimeter did you use ? What you woukld need is a rms-meter capable of measurements up to 100 Khz at least.
Kator01
v8karlo
In this setup TK is filling his big outer coil capacitor to
max capacity, spark gap removes overload from minus
plate, otherwise it wil arc. And thats one separate
circuit. He is creating strong cap field with that cap
coil. You can use coaxial instead. Coil inside pipe
is positive and outher is negative.
Second circuit is beneath where is 2 coils wound
in oposite direction and my guess is he is driving
second circuit through one of that 2 capacity coils
which in strong field yield much more than my setup.
Thats what I realised today from pictures, and tomorrow
will try that teory.
This type of coil you dont drive with high voltage,
because it loves fat input capacitor. I tried with
2000V, 0,1 uf cap and did nothing, but 200V and
5 uF did yield good results.
I am not trying to full anyone around, I told you
everything I know. Try yourself, setups are trivial,
learn about capacitive coils, test it and you will see
for yourself.
Then compare it to TK setups and lots of similarities
will emerge.
Zeitmaschine
them.
Strange. I have been experimenting for months (since March of this year) with all sorts of coil configurations. Coils on top of each other, coils side by side, bifilar and non bifilar, with ferrite and without ferrite, with and without helical (Tesla style) coil. With all possible frequencies with and without high voltage. No success so far in respect of over unity.
BTW: The 100µF capacitor shorts the input for high frequencies. How can this ever work?
