0 Members and 131 Guests are viewing this topic.
v8karlo
Quote from: verpies on August 16, 2012, 06:59:28 PM
Because it is rectified direct current at output,
Are you sure it is DC and not pulsating unipolar current (aka. Pulsating DC) ?
Any chance of seeing scopeshots of I/O waveforms?
Well , I did have Scope and I did attach it to output until i forgot
to attach output cap. When I switched on I realized what I have done.
My scope was gone. Without output cap voltage raises well over 2000 volts
in my setup in split second.
Second time I killed my hard drive through Pc Scope and scope stayed alive.
Until that day I didnt attaching my new PC scope to output of that thing,
but only to test my mosfets and signal gen.
But output looks like smooth cap discharges with very high and short voltage peaks
at the begin of discharge.
a.king21
v8karlo:  In your second post you mentioned you obtained approximately 1 kw output from 3 watts input.
Can you post exact schematic of the circuit and a list of components used please?
The most important thing in any thread is that the circuit is independently verified.
Remember there have been many circuits posted and nothing came of them.
I happen to think that you've got something here. So fingers crossed.
You use the transformer in exactly the same way Jack Noskills does, except you've taken it further.
It could be that Jack Noskills is also a capacitive effect.
Hopefully we can then collectively develop the circuit.
Hoppy
Quote from: a.king21 on August 17, 2012, 02:58:12 AM
v8karlo has stated that he had not taken a loaded output power measurement, so he presumably took the 900mA - 1100mA output short circuit current (with meter directly across output) and 1200V open circuit voltage stated in his post 13151 and came up with approx 1KW (P=VI). A true power measurement has to be taken with a load and the output power will likely vary with load and the output voltage will of course drop below the open circuit measurement.
Hoppy
4q
Quote from: v8karlo on August 16, 2012, 08:31:44 PM
Karlo, didn't you do that the same what JNAudin did in the 90's: http://jnaudin.free.fr/html/tepv22.htm ?
Your coil setup and pulsing very-very similar for me like Naudin's setup. Please check TEP pages here: http://jnaudin.free.fr/html/scalwidx.htm
4q
