0 Members and 245 Guests are viewing this topic.
forest
Page 881  ;D  Maybe we can extent it to 1000 before 21 Dec 2012  :P
Good that you catched electrostatic effects
frantz
Quote from: yfree on August 17, 2012, 11:48:59 AM
Hoppy, All,
You are absolutely right. The amount of energy produced by TK devices can only be achieved through reactions in the "deepest hidings of matter".  There should be no doubt that TK devices are real, they are energy converters, not energy creators.
There  were many suggestions on how to approach this problem. The hints came mostly from TK himself (through his videos, not his talk), Wesley, verpies and sometimes myself.
However, there was no discussion in relation to these suggestions. If at all, there was only outright rejection of these ideas.
It is understood that playing with various implementations of back EMF is fun and the results are immediate; the bulbs are shining with reasonable efficiency, the spark-gap is  firing...  Playing with resonance can also be rewarding: e.g. the Tesla coil will produce high voltage, if implemented properly. But without creating conditions that would involve the "hidings", the results will be, as they always have been.
This is not to discourage anyone from experimenting and reporting results, having fun; quite the contrary.
This is about expectations.
P.S. Output voltage and output current have to be measured simultaneously, not separately, to estimate the output power.
Hi I must agree with you in measurment case.
For power measurment is very important to measure both values simultaneously like aperage and voltage.
v8karlo have very fresh look on OU and his solution is very promissing, but without correct measurment is a toy, I'm sorry for this word but this is true.
And one thing, what about automatic resonance? This was a story about a dragon? :)
regards
Zeitmaschine
Quote from: v8karlo on August 17, 2012, 09:28:50 AM
Caduceus coil is pure capacitive coil.
I played with it for a long time.
If you wind it with wire of different color, you can clearly
see plates of cap. Windings must be tight, closest the plates,
stronger the capacity. Connect it as scheme shows, just like bifilar
one and it will yield great results.
There is one other thing about it. On the up and down overlaps
it emits strong pulses.
It gives me something to think for a while and whats happens is that
electrons travel through windings in different directions, and when they
hit overlap points, under their strong repulsion they have been ejected
from coil.
Caduceus coil, when operating with heavy load emits strong pulses which
lit diodes on my Pc keyboard meter away.
After I understood whats happening I came up with HV experiment and it
succeeded.
HV Schematic is attached below.
This is very strong force and my intentions were to instead of small cap put
capacitor coil  as an driving coil. It would be far stronger then classic induction.
That was my first thought that TK is doing just that with his big Capacitor coil,
but never tried.
Now you know everything I know.
Interposed question: If this is Kapanadze scheme then how to get 220V/50Hz output like shown in TK videos?
How to get or manipulate 50Hz frequency without an iron core transformer? ???
v8karlo
Quote from: starcruiser on August 17, 2012, 10:07:05 AM
The spark gap in this setup is for demo purposes only as this is on the output of his trafo setup. In all cases I am thinking the SG is for over voltage protection and not part of the power generation, at least in this situation.
I am getting ready to try a few experiements myself, just finishing up my secondarys for my Tesla coils then I can focus on the cap coil idea, going to try air core first then try with a ferritte core. Now what would happen if one would cascade 2 such units? what would the output be?
This setup reminds me of the SM TPU large center core torrids, I wonder if this was the secret, input caps (yellow), 555 timer circuits for driver and a second air core coil for amplification, just thoughts... something to try I suppose.
Thats right, spark gap was only demo to show that HV voltage is present.
This setup isnt miracle kW power plant. It is new way of induction which
is more efficient than classic one. It works in a different way and show us
new paths.
It works like capacitor and when capacitor is in strong external field, charges tends
to separate on its plates, it is natural way and it is not something new.
Maybe TK dont drive his capacity coils at all. They are under HV strong Capacitor Coil
and in its strong field and in that field charges in that 2 coil tend to separate naturally
without external driving and maybe you just have to pulse output to get charges move.
Attach small led diode to small electrolitic cap and put it in dense field of tesla coil and
led lits, same thing with strong cap field, maybe this is principle of his device but made with coils.
Anyway, we are closer to truth than yesterday, thats for sure..!
I was watching his videos many times and my opinion is that the theory of capacitive
separation of charges under the strong static field holds the water.
In that case you dont spend much energy, only to drive flyback to maintenance
big outer capacitor coil full at all time. And his consumption is 200-400mA, 220V.
If you drive any coil inductively you will spent much more, but if you drive only
flyback to maintenance charge on cap you will spent exactly that amount
of energy.
So this isnt my quest to full you around. I just gived you few new fresh ideas which
has logic in it and can be done without rocket science.
TK isnt using mosfets, but bipolars and his freq. is very low but he is using caduceus
which is best capacitive coil I've seen. Remember Stiveps video. Caduceus and
Coaxial at one end, which can be capacitor.
Good thing is that we started to understand processes in his device and it wont be long
before someone hits the right combination.
yfree
Quote from: Zeitmaschine on August 17, 2012, 12:56:49 PM
It is very simple: all that is needed is the rectifier and  the DC to 220V/50Hz inverter  :D .
